Stiff, tight Automatic shifter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Namastizzle, Mar 6, 2017.
  1. Mar 6, 2017 at 1:06 PM
    Namastizzle
    Namastizzle [OP] New Member
    Hey,
    First post here.
    Stats: 2009 Tacoma Access cab SR5. 4WD. 105,000 miles. Vermont. Salty. Pretty good rust on the frame. Had some recent rust / wear related replacements - broken coil springs, catastrophic (well, kinda) front brake caliper failure. Only owned her for about 16 months. Bought it at 94K miles.
    The truck is VERY tough to shift. Been getting progressively worse over the last 3 months or so. Gets worse if the truck sits for a while, but not too much better when its warmed up. It gets progressively more difficult to engage the shifter the farther down you go. Can't physically get it in to second of first. If I don't pay attention it will actually drive without being all the way in D and then will slip out of gear altogether. Have to strongly pull it down into like 3rd or 4th and then back in to D to get it to stay there.
    My local guy has tried first just lubing the whole mechanism. Didn't work. Recently he tried replacing the entire cable. Didn't work.
    It doesn't feel like a transmission issue to me, but maybe that's just wishful thinking.
    So I'm stuck. I can't bring myself to go to the local Toyota dealer, and I've got to imagine I'm not the only one with this problem.
    Thanks in advance for any help or ideas.
    JB
  2. Mar 6, 2017 at 5:42 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Tried disconnecting cable at trans ? If shift fine then its trans I would think
  3. Mar 6, 2017 at 5:53 PM
    RedTac0ma
    RedTac0ma Member
    The neural safety switch on the transmission is binding
    Too Stroked and Jimmyh like this.
  4. Mar 6, 2017 at 5:54 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    So you have a stiff knob and your local guy tried lubing it?
    :rimshot:
  5. Mar 6, 2017 at 5:55 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Yea if its trans side would be next thing to check.
  6. Mar 7, 2017 at 6:19 AM
    Namastizzle
    Thanks all,
    The neutral safety switch - or something associated with it, was one of my guesses. Any ideas on how to "unbind" it?
    and @KenLyns - I knew someone would go there...
  7. Mar 7, 2017 at 8:28 AM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Tale it off and try to turn . Shouldnt be hard to turn. If hard to turn buy new switch
    Cant un bind
  8. Mar 9, 2020 at 9:28 PM
    razman
    razman New Member
    2016 Tacoma 4x4. My wife and I travel to SC (grandkids) from OH often. My Tacoma stays in OH parked for 2-4 weeks. Upon return, ALWAYS very stiff when moving shifter. This time it was stiff yet again AND threw a code P0705. TRAC indicated off, and D (drive) would not indicate/light on dash display or shifter. With engine off but key on, worked the shifter between P and D for easily 5 minutes to free up the shifter. FINALLY it loosened up but still no D indicator so I worked it some more. Bingo. D started to indicate. I cleared the P0705 and all now back to normal. I guess I'll have to find the TRS (also known as PNP) switch/sensor and lube it silly. My guess is weather has gotten into itcreating corrosion.
  9. Mar 10, 2020 at 2:37 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Dude, I hate to break it to you, but your going to have to replace the switch assembly.
    I don't know what a TRS or PNP means the way you are using them.
    This is similar:
    https://www.toyotanation.com/threads/removing-and-cleaning-the-neutral-start-switch.245436/
    The Tacoma switch looks like the image below and seeing as how you live in one of "Those States" it is going to be a rusty mess and a pain in the @ss to get off. The two sides of the switch are riveted together. Good Luck!
    Garin113 and Too Stroked like this.
