Stiffer front coil option
Discussion in '1st Gen. Tacomas (1995-2004)' started by Northern Taco, Sep 26, 2016.
  1. Sep 26, 2016 at 1:10 PM
    Northern Taco
    Northern Taco [OP] Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    well guys my battle with Toyota Canada ended and I am stuck with my patched frame.
    So instead of paying Toyota for new sway bar mounts and welding them back onto my frame, and replacing my end links, I was wondering what front coil over set up would reduce my body roll? I don't want any lift as my truck sits high enough for my use. Don't need bigger tires to reduce my mpg
    Shock valving plays a large roll in this as well (reducing body roll)
    I'm in Canada as well, and not looking to spend a ton for the best, just something that works.
    I prefer the articulation without the sway bar honestly, but if a deer jumps out infront of me @60 mph I fear for my safety. Lol
  2. Sep 26, 2016 at 1:17 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Don't know what the back ground is you're alluding to but if you're only concern is body roll you should find a way to install a new sway bar. You'll never be able to balance normal suspension articulation and body roll using only the coil springs. It will always be too stiff or loose in one respect.
    Wulf likes this.
  3. Sep 26, 2016 at 1:27 PM
    Northern Taco
    I know people on here are running different coil over setups and with stiffer springs and better shock valving without a front sway bar with success.
    Was wanting to hear more from them about their setups and such
  4. Sep 26, 2016 at 1:35 PM
    Northern Taco
    I am confident with my driving. Just if a deer jumps out infront of me it's going to be a wild ride.
    I have ran many off road toys (ski-doo) and currently a wildcat sport without front sway bars, but like you say, they all had low speed compression dampening adjustability.
    I'm just looking for experience from people with various shock/coil set ups that come with better valving to reduce body roll
  5. Sep 26, 2016 at 1:40 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    without any lift youd need an expensive coilover to get the right coil. you could weld on some sway bar mounts for under $100.
  6. Sep 26, 2016 at 1:45 PM
    Northern Taco
    I might end up doing that. You price them at a Canadian Toyota dealer?
  7. Sep 26, 2016 at 1:55 PM
    devinzz1
    devin
    2023 aclb trd or mt
    that was just a guess. you can buy universal ones though. just measure the diameter of the sway bar and buy online.
  8. Sep 26, 2016 at 2:37 PM
    Northern Taco
    I tried but didn't have any luck.
    $35 usd was what I read from dealer
