Stiffer springs coil question
Discussion in 'Suspension' started by Slvr14tacoma, Sep 30, 2017.
  1. Sep 30, 2017 at 3:09 PM
    Slvr14tacoma
    Slvr14tacoma [OP] Well-Known Member
    Mid travel
    i see people post stuff like "no more preload with new 700lb springs" since they've switched out their 14" 600lb springs for 700# springs. This would put lca at better angle right. How are they getting the same amout of lift with effectively shorter coilovers (less or no preload). By preloaded coilover you are lengthening the strut correct? My dumb question for the day
  2. Sep 30, 2017 at 8:01 PM
    Slvr14tacoma
    Mid travel
  3. Oct 10, 2017 at 10:28 AM
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    The amount of preload to achieve desired lift depends on many factors. Most guys with steel bumper, winch, etc go with heavy springs, gets to desired lift without so much preload, allows you to have max up/down travel compared to a heavy preloaded lighter spring. Short story, can get same lift without preload.
    Slvr14tacoma[OP] likes this.
  4. Oct 10, 2017 at 10:30 AM
    eon_blue
    Azusa, CA
    Someone with a lot of weight on 600lb coils is going to have to increase the preload on their shocks to compensate for the sag being created by the weight they've added. When they upgrade to 700lb coils, the coils no longer sag under the weight so they are able to run their shocks with little to no preload because they are no longer having to compensate.
    Slvr14tacoma[OP] and abqnurse80 like this.
  5. Oct 10, 2017 at 10:37 AM
    Slvr14tacoma
    Mid travel
    I was thinking by preloading springs you are lengthening coilovers but im probably wrong
    abqnurse80[QUOTED] likes this.
  6. Oct 10, 2017 at 10:38 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    You are, but it takes more preload with lighter springs to get to the same hight with stiffer springs and less preload
  7. Oct 10, 2017 at 10:42 AM
    Slvr14tacoma
    Mid travel
    At least it seems like by putting preload on coil you are putting shock in extended position therefore you are lengthening the total coilover length giving you lift. As well as stored energy in compressed spring. But i just read somewhere that preloading does not lengthen but it sure looks like it does. At least in ny head. So all lift is achieved from compressed coil energy?
  8. Oct 10, 2017 at 11:41 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
  9. Oct 10, 2017 at 3:26 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Control arms will always be at the same position/angle for the same amount of lift(unless the length of the control arms changes) regardless of preload or spring rate.
  10. Oct 10, 2017 at 3:46 PM
    Slvr14tacoma
    Mid travel
    Thats what i was curious about mainly thanks
