Still Able to Reinsert New Idler Tensioner Pin After Removing It?
Discussion in '1st Gen. Tacomas (1995-2004)' started by windnsalsa, Feb 19, 2017.
  1. Feb 19, 2017 at 3:40 PM
    windnsalsa
    windnsalsa [OP] Active Member
    2001 Green Tacoma TRD 3.4 manual [110k+ mi as of 02/2017]
    2001 Tacoma 3.4L 5vzfe 110k+mi:
    I am in the reassembly stage of a timing belt/water pump replacement. I've installed a new oem tensioner. Pull out its pin. Even after 1 hour, I can still reinsert the pin. Turned the crank 2 revolutions and all 3 timing marks on cams and crank lined up. The belt seems to be as tight as before installing the tensioner.
    Is this normal? Or is there something wrong with the tensioner?
    Or does the tensioner kick in and start to increase tension after the belt slacks a bit initially when engine is on after completing the project?
    thanks
  2. Feb 19, 2017 at 8:48 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Probly this. I remember mine didn't move much when I pulled the pin.
  3. Feb 20, 2017 at 7:37 PM
    windnsalsa
    Ok thanks. I'll ignore my observation and continue with the reassembly [hoping the rain stops soon].
