Still at a lose.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dlbfla, Aug 16, 2017.
  1. Aug 16, 2017 at 7:09 PM
    Dlbfla
    Dlbfla [OP] Well-Known Member
    Fla.
    07tacoma
    Replace both front hub assembly's center support bearing and checked all u joints and pinion. But still have a growl. Tried running in 4x4 and no diffrence in sound. I can make a hard right turn and load up the left side and it gets worse. Haven't lifted the rear up yet but don't see any failing seals on either wheel.
    Could it be a left rear bearing sense it gets louder when loaded. I know they don't have to have any play and still be bad from what I hear.
  2. Aug 16, 2017 at 7:14 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Yes, check the left rear if it gets louder when turning right
  3. Aug 16, 2017 at 7:20 PM
    Jonas
    Jonas Boogerrrrrr!
    Springfield, OR
    05TRDSport
    ARRGH!! I CAN'T HELP IT!!
    Loss
  4. Aug 16, 2017 at 9:21 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I think I read your other post. Dumb question, but have you reengaged 4H then driven a few yards, then 4L for a few more yards, then gone back to 2WD?
  5. Aug 17, 2017 at 6:32 AM
    Dlbfla
    Fla.
    07tacoma
    Yes. Still the same . I'm thinking rear wheel bearing because it gets louder when I make a hard turn.
  6. Aug 17, 2017 at 6:35 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the heat shields on the cat aren't loose and rattling
  7. Aug 17, 2017 at 1:10 PM
    Dlbfla
    Fla.
    07tacoma
    Pretty sure it's the rear bearings.
    On another note looking at some 17" x8.5" lonestar wheels by american outlaw wheels. Is a -10 offset good. I don't want to be outside the fender would like to be close to flush with the fender.
    Thanks for all the help diagnosing my growl problem.
  8. Aug 17, 2017 at 4:21 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    You missed "sense", should be since.
    Jonas[QUOTED] likes this.
