Still can't get rid of low speed shudder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clankey, Jul 6, 2010.
  1. Jul 6, 2010 at 5:45 AM
    clankey
    clankey [OP] Well-Known Member
    St. John's, NL
    2010 Double Cab TRD Sport
    Roof Rack, Soft Tonneau, Running Boards, DDM HID's, Skid Plate, 3" lift, 275/70R17 BFG AT TA's
    Ok so I have had my 2010 Tacoma Double Cab long box now for 2 months. I had a Tough Country 3' lift done when I purchased it and I have a shudder going through the truck when I take off from about 10kph to 20kph. I have tried putting washers under the carrier bearing as suggested but NOPE still there.
    The only thing that seems to eliminate it is when I have weight in the box of the truck. Obviously leaving the box loaded with something is not the best idea in the world so I still need more suggestions for help.
    Thanks Again Everyone!!
  2. Jul 6, 2010 at 5:55 AM
    ExFordFan
    ExFordFan Semper Fi
    Mark
    Wauwatosa, WI.
    Stock
    Sound to me that your shudder is definately a drive line angle issue. Have you put an angle guage on the drive line to see exactly what it is? The washers you put in may of been to much or possibly not enough. I'm don't know what the spec is for the angle but maybe some one here or possibly a local driveshaft shop would be able to help you with that one.
  3. Jul 6, 2010 at 9:19 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R TRDOR Premium. ‘01 Tacoma Xtra Cab 4x4
    A good tire/wheel balance and a stack of 4 washers took care of mine. Cheap and effective
  4. Jul 6, 2010 at 9:32 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    axle shims, Im running a 2* with my new leafs (about 2" of lift)
    but I do still have a slight shudder at about 10 mph, I live with it.:D
    now if I could only get the slip yoke(at the trans, 2WD auto) to work properly and not clunk sometimes. or a carrier bearing delete:eek:
  5. Jul 6, 2010 at 10:00 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    If it works better with weight in the back that would mean you have too few washers under there.
  6. Jul 6, 2010 at 10:05 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    actually the opposite. the weight would push the chassis, and bearing, down further and the vibes go away meaning you want the bearing lower without the weight, more washers. that would either mean not enough washers or you need a wedge (shim) to angle the rear axle.
    misread thought you said too many...
  7. Jul 6, 2010 at 2:23 PM
    clankey
    St. John's, NL
    Thanks everyone!!! I will try a couple more washers I guess.
  8. Jul 8, 2010 at 3:05 PM
    clankey
    St. John's, NL
    Just tried more washers but nope....no help. Anyone have any pics of installing Axle shims....I dont have a clue what to use or where to put them!
  9. Jul 8, 2010 at 6:22 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    they go between the axle perch and leaf spring(kinda like a real small angled add a leaf) therefore shimming the axle to a proper angle in respect to the driveshaft/carrier
