Still Got Vibes!?
Discussion in 'Suspension' started by bowhuntingaddict, Aug 28, 2010.
  1. Aug 28, 2010 at 6:53 PM
    bowhuntingaddict
    bowhuntingaddict [OP] Well-Known Member
    I just got bilstein 5100s set at 2.5 with a 2in aal in the back, with the diff drop kit (stock UCAs), and im running 285/75/16 bfg TA/KOs with helo wheels on a 4x4 DCLB sport. I got everything put on with alignment. There is a considerable amount of shaking in the steering wheel between 40-65mph. I got it road forced balanced at discount tire where the wheels and tires where put on, but there isn't any improvement in the vibrations.
    Not sure what to do: carrier bearing drop kit, axle shims, new coilovers, get it rebalanced somewhere else, or something totally different??
  2. Sep 11, 2010 at 8:33 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    try carrier bearing first. i got a 2 inch aal in the back and the angle looks pretty severe on the drive shaft.
  3. Sep 11, 2010 at 6:46 PM
    bowhuntingaddict
    this might be a stupid question, but im not too familiar with the parts on my truck, so what exactly is the difference between a differential drop kit and a carrier bearing drop kit?
  4. Sep 11, 2010 at 6:47 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Got any pics of the truck?
  5. Sep 11, 2010 at 7:24 PM
    bowhuntingaddict
    Heres some pics
  6. Sep 11, 2010 at 8:42 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    A D/S spacer and axle shims is where I would start if it feels like its under the seat after you get the front balanced. Sounds like the front wheels need to be rebalanced from incorrect balancing or it could've thrown a wheel weight.
    Truck looks great BTW
  7. Sep 12, 2010 at 1:34 AM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    These tires are hard to balance . My neighbor has same tires as your and He 's still getting vibe at 65 miles . He also got 2.5" lift on his truck .
    I got Handkook Dynapro ATM 265/70/17 set at 2.5" w/o any vibration any speeds at all .
  8. Sep 12, 2010 at 9:00 AM
    nighthawk87
    nighthawk87 Well-Known Member
    Carier Bering is where the two drive shafts meet. It's like a u bolt/flange. Unscew it and stick a few washers inside until the vibes are gone...tadaaa or you could try raising lowering the front end if u have coilovers. If u don't have coilovers...oops. Better luck next time
  9. Sep 12, 2010 at 10:17 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    they are completely different from one another, a diff drop kit lowers the front diff usually 1''(depending on kit) and from im told isnt always to beneficial for 2nd gens. a cb drop will lower the center of your driveshaft to correct pinion angle. a toytec cb drop kit lowers it 3/8'' IIRC,but you could make one yourself very easily with some steel and hole through the center or just use washers if ya prefer.
  10. Sep 13, 2010 at 8:08 AM
    MAtrdguy
    MAtrdguy Well-Known Member
    Pete
    Western Ma ( on the lake) / Danvers N Shore
    06 Taco DC LB
    None YET
    what is the max the CB can be dropped, I have the CB Drop on the truck, can I go down even more by adding some more washers ?
    ( still getting a vibe.) ????
  11. Sep 13, 2010 at 1:47 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    u can only go as far down as the bolts will let you,so about an 1'' id say before theres no more threads. unless you pick up longer bolts of course. if you go down that far i wouldnt want to use washers id sooner use more steel because it would provide more stability for your ds.
  12. Sep 13, 2010 at 3:42 PM
    MAtrdguy
    Pete
    06 Taco DC LB
    None YET
    what effect will lowering the CB some more have ( I already have the one from Toytec on there. can I go to a full inch with longer screws ??
    any detrimental effects to that ?
  13. Sep 13, 2010 at 6:11 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    i cant see why you couldnt as long as it is stable, if you do go with longer bolts make sure they are of a high grade. before i bought my 1 piece ds i had about an 1'' worth of steel under the bolts.
  14. Sep 30, 2010 at 7:40 PM
    malander
    max
    01 limited trd 4x4
    iirc beefed tacos goes down 2 3/8 inches and uses a solid steel bracket instead of just washers and includes grade 8 hardware
  15. Oct 1, 2010 at 3:03 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    yah beef's cb drop is definitly the better way to go no doubt,not sure what the price is but it looks like it would be worth the money.
  16. Oct 1, 2010 at 3:26 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    to the OP heres what Beefed Taco's CB drop bracket looks like that we were talking about,drops it a total of 2 5/8''
    heres what it looks like installed
  17. Oct 1, 2010 at 3:36 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    These two articles will explain how driveshaft alignment causes vibration, and what to do about it.
    http://www.4crawler.com/4x4/CheapTri...line-101.shtml
    http://www2.dana.com/pdf/J3311-1-HVTSS.PDF
    Basically, you want to get your driveshaft flanges back to perfectly parallel, or a little *tiny* bit "pinion down."
    One way to do this is with a little bit of carrier bearing spacing, the other is with angled rear axle shims between the leafs and the axle.
    I cannot help but think that a 2.375" carrier bearing drop - which is huge - will solve the problem - rather move it from one part of the shaft to another.
  18. Oct 1, 2010 at 3:41 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    start with the easiest thing: take it back to discount and make sure they are using the correct adaptor. just being in the shop breathing down there necks and mentioning this helped me out a lot.
    Then start to mess with things like carrier bearing drops and such. Carrier bearing drop for me only helped eliminate the take off vibs. Axle shims have helped alot of people for higher speed.
  19. Oct 1, 2010 at 3:42 PM
    08pretaco
    Oliver
    az
    It could also be that the tires have been "worn" in getting used to the OLD suspension angles and geometry and the tires do not like turning with the new geometry
