Still have shimmey after new tires and aligment
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rockchalk, Sep 9, 2010.
  1. Sep 9, 2010 at 6:03 PM
    Rockchalk
    Rockchalk [OP] Member
    Kansas
    03 PreRunner Limited
    Have a 03 2WD Auto with 16 in. tires Limited Prerunner 4 door. Bought used with 68,000 miles. Had a bad shimmey at around 65 MPH. Got new tires mounted and balanced. Had front end aligment also. Drives straight and still has a slight shimmey at 65 MPH. Its much better, but it is still there. Any other ideas. When brakes are applied hard, seems to have similar shimmey. Any ideas would be great. Thanks.
  2. Sep 9, 2010 at 6:06 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Brake shimmy is usually warped rotors.
    While driving, if alignment is good and wheels balanced, than it's probably worn suspension components; most likely worn ball joints.
    Do you feel it more in the steering wheel or in the seat?
  3. Sep 9, 2010 at 6:18 PM
    1stgen7
    1stgen7 Member
    Salt Lake City
    03 TRD SR5 4x4 XtraCab
    Mine does the same thing. I feel it in the steering wheel a lot when I brake. What would be the cause of this? New wheels, tires, balanced, aligned, and 5100s all the way around.
    Sorry for the threadjack, but didn't want to start a new thread and it seems we may have similar problems.
  4. Sep 9, 2010 at 6:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    They need to Road Force ballance the tires.
  5. Sep 9, 2010 at 6:27 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Sounds like two different shimmies.
    The first, speed-specific shimmy is often caused by incompetent tire balancing, which is very common these days (and on this forum). I had new Michelins (stock size, stock wheels) put on mine with an alignment, and it shimmied on cue at 55-65. Took it to another shop who had their act together, and they got it right, first time. So eliminate the balance issue first before you attack other stuff.
    Do you have the aluminum wheels? They are kind of notorious for being difficult to balance. Toyota has a special Haweka adpater they use, if another shop can't get it right. Also, they will likely need to add weights to the outside of the rim.
    Brake shimmy? Warped rotors, most likely.
  6. Sep 9, 2010 at 6:32 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    I have my tires balanced at a shop that does on the car balancing....they have balanced 2 tacos that i owned and it is perfect every time! Just had my new set of duratracs balanced today. Look for one around your area. They are pretty rare....
  7. Sep 9, 2010 at 7:35 PM
    Rockchalk
    Kansas
    Thanks for the advise. Walley world mounted them, but I bought them from Discount Tire.com. And they still gave me a free lifetime of tire balance and rotation for $50.00 for mounting and everything. The tires that were on the truck were cupped inside and looked to have never been rotated. So when I went to get it aligned, the guy said it was in specs and just adjusted a small amount. I do have aluminum wheels. And you really don't notice it in the steering wheel, as much as the body itself. The ball joints were recalled and I called a toll free # for Toyota and was told it had the recall work done. But wouldn't give me any details of when or where the work was done. Big Seceret I guess. How about u joints?
  8. Sep 9, 2010 at 7:54 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner
    bent wheel or mud on the inside of the wheel maybe
  9. Sep 9, 2010 at 9:39 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    Check your tire pressure. Tire shops are notorious for over inflating tires.
    I think it was chris4x4 who did a great writeup on tire pressure.
  10. Sep 9, 2010 at 9:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Go here: http://www.toyotaownersonline.com/
    You'll have register, put in the vin#, you'll then have access to any records kept by Toyota on your truck, including when and where the ball joints were done.
  11. Sep 9, 2010 at 9:50 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I was kinda thinking the same thing as far as bent center hub or warped lug holes in rim..
