still have vibrations after several repairs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by christhemainer, Sep 14, 2012.
  1. Sep 14, 2012 at 6:15 PM
    christhemainer
    christhemainer [OP] Member
    Saint Petersburg
    06 SR5
    Pro comp 6",LR uca, cobra 29tld chrome with 3' firestik, pioneer head unit with 10" kicker, Bestop supertop
    2006 Tacoma 137,000 miles went mudding ran it hard got a bad vibration.
    What I have tried after reading posts.
    U-joints
    Carrier bearing
    Still had vibration pulled rear drive shaft figured no vibration must have messed
    Up the carrier bearing had a one piece drive shaft built before it was finished had the vibe again read about bad tranny mount replaced that put the drive shaft in and still have the dam vibration have only had the truck for a few weeks and I broke it :( it still vibrates if I use 4H if I run it in 4th instead of drive it does not vibrate it has a lift on it 6 inch I think vibration around the 35 mph mark the vibration is also not as bad as it was but still bad to the point of concern any and all suggestions will be appreciated:D motor mounts or could it be a unbalanced tire Maybe a drain and fill of the transmission I really don't want to bring it to a shop I like working on my on stuff and this is a great forum
  2. Sep 14, 2012 at 6:47 PM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Sweet Grammar baby jesus! Please use complete sentences and punctuation marks so we can get an idea of what's wrong and what you have attempted to repair.
  3. Sep 15, 2012 at 5:12 AM
    christhemainer
    Saint Petersburg
    06 SR5
    I have replaced:
    U-joints
    Installed a single piece drive shaft
    Replaced transmission mount
    My taco has a vibration between 25 and 35 mph.
    It still vibrates in 4h if I drive it 4th in stead of drive I do not get the vibration.
    What would be the next thing to try?
  4. Sep 15, 2012 at 7:33 AM
    BamaToy1997
    Bill
    Navarre, FL
    So with your transmission in 4th instead of drive, you do not get the vibration between 25 and 35 MPH? If that is accurate, I would look at the following initial inspections:
    1. water/contaminants in transmission fluid
    2. proper fluid level
    3. loose linkage allowing "play" at transmission
    4. electrical connection at transmission (loose/bad connection)
    I suggest this because if the vibration is at that speed, and does NOT show up when in 4th gear, then it has nothing to do with mounts or driveshafts because those are normally rotating at the same speed because your transmission should be in the same gear at 25-25 MPH (dependent of course on acceleration and driving style)
    This vibration you are feeling, does it change based on how hard/easy you are accelerating, or is it the same? Does it go away when you are holding a steady throttle at 25-35 MPH? Does it vibrate accelerating AND decelerating in that vehicle speed range?
