still having problems with my idle
Discussion in '4 Cylinder' started by jrbauserman, Mar 17, 2013.
  1. Mar 17, 2013 at 11:25 AM
    jrbauserman
    jrbauserman [OP] Member
    Montana
    97 Tacoma 2.7L
    Ok so my 97 2.7L with 277,000 mi. idles high. I took off the throttle body and cleaned it including removing the IAC which did not look bad. The ilde is about 300-400RPMS high. the coolant level is good but I was thinking about replacing the temp sensor anyway the part is much cheaper than an IAC valve. When I had the throttle body off there was a large amount of carbon just inside the intake where there is a port to the EGR valve. I cleaned that out also with no change in idle. anyone have any suggestions? I really do not want to throw a $160 IAC valve at if im only guessig. If I know that will fix it I have no problem doing it.
  2. Mar 17, 2013 at 11:48 AM
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    Was this something that was gradual or literally on the next startup?
  3. Mar 17, 2013 at 7:34 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Sticky throttle cable or misadjusted cable stop maybe.
    Also I had a ford stuck in closed loop cycle or such, had to get some egr stuff fixed too, you might need to do more there.
