still having sub trouble... PLEASE HELP =(
Discussion in 'Audio & Video' started by DSully72, Nov 20, 2010.
  1. Nov 20, 2010 at 6:02 PM
    DSully72
    DSully72 [OP] 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    okay guys im having trouble again with my system... i have new subwoofers, a new cd player, a new amp, and a new wiring kit... i dont understand what could be goin on.... but im not getting any signal to my subs still... if i turn up the gain on the am i can get a very little signal that i can barely feel by feeling the center of the subwoofer, but that all i can get constantly... HOWEVER.... when i turn up the gain on the amp fairly significantly, it jumped from being so quiet you cant hear the subs, to incredibly loud for only a split second... im very confused and have no idea what on earth could be goin on... PLEASE help me out guys... i know im dumb as hell when it comes to this audio stuff... but i need help. im gonna try and cooperate as much as i can, but if i have a hard time catching on please bear with me.
  2. Nov 20, 2010 at 6:16 PM
    DSully72
    Daniel
    Appling, GA
    bump please =/
  3. Nov 20, 2010 at 6:26 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Sounds like you're amp could be screwed up. Re-check your wiring, negatives are running to negatives, etc. I run a 0 gauge wire to ground my amps (if you don't have one). Whatever you are grounding it to make sure you have the paint sanded off and it's just bare metal or you won't have a good ground. That's my advice, i could be wrong i dunno. Sound usually is hard to know what's wrong with it when you really can't get your hands on it, good luck with the fix.
  4. Nov 20, 2010 at 6:30 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    I'm an audio boob myself, but perhaps a bad power/ground connection on the amp?
    You might be able to slip a 20 to a car audio shop worker and get some pro help
  5. Nov 20, 2010 at 6:40 PM
    DSully72
    Daniel
    Appling, GA
    i made sure when i grounded it i grinded all the paint off. i have it grounded to once of the posts on my passenger seat cuz thats where the amp is, under the seat. i have no other place to put it... but im pretty sure its not my grounding...
  6. Nov 20, 2010 at 6:48 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    try turnin the bass down on the radio its self
  7. Nov 20, 2010 at 6:50 PM
    krimson
    krimson Nothin
    TRD Off Road
    If you can get a friend that has a amp and is willing to let you test it out and install it that would be the first thing i would do, to know if you're amp that is causing the problem or its something else.
  8. Nov 20, 2010 at 7:54 PM
    DSully72
    Daniel
    Appling, GA
    my bass and everything is set to 0 where it should be. and it cant be my amp... i hooked up the cd player from my old truck to the amp in this truck and my system worked....
  9. Nov 20, 2010 at 8:05 PM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    How about a little more detail on where you grounded your amp. You say one of the posts of your passenger seat. You mean the bolt that secures the seat to the chassis right? If yes, where exactly did you grind paint from? The seat bracket that's part of the seat or the paint from the truck chassis? Make sure the ring terminal on your ground wire from the amp is solidly attached to the chassis.
  10. Nov 20, 2010 at 8:09 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Did you replace all of your audio cables as well?
  11. Nov 20, 2010 at 8:10 PM
    DSully72
    Daniel
    Appling, GA
    yes, i grounded my amp to one of the bolts that holds the seat in place... i took the paint off the chassis and the bottom of the foot of the seat. i have the ground wire going between the foot of the chair and the chassis with the bolt holding it all in place
  12. Nov 20, 2010 at 8:11 PM
    DSully72
    Daniel
    Appling, GA
    no but they are all brand new... i mean i just bought them with the rest of my stuff... the only way they are used now is they were in when i blew my subs like a month or maybe a few weeks ago.
  13. Nov 20, 2010 at 8:14 PM
    kcrob1
    kcrob1 Choot It!
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Adjustable Billies, Debadged, Painted emblem on grille Kenwood Double din, polk components, co-ax, polk 8" sub & polk amp, TSB springs, 6000K hids, FJ Wheels
    Could be blown voice coils. Try to push in the sub and see if they start working and when you let go they stop. I had some that did that to me a while back. Same symptoms as you are having.
  14. Nov 20, 2010 at 8:14 PM
    krimson
    krimson Nothin
    TRD Off Road
    Then it's you're Head unit that's causing the problem.
  15. Nov 20, 2010 at 8:16 PM
    DSully72
    Daniel
    Appling, GA
    my subs are brand new... i got a new pair becuase the old ones were blown... and besides thats not the case. i did try that... and also my cd player shouldnt be the issue... i got it brand new last night and installed it last night... could it be just my rca cable?
  16. Nov 20, 2010 at 8:17 PM
    DSully72
    Daniel
    Appling, GA
    oh and adding on to my reply to you kcrob1, like i said i used another cd player with my system and it worked just fine... =/. i hate to admit that it may be m y cd player.... but unless its my rca cable or a grounding issue, thats probably what it is...
  17. Nov 20, 2010 at 8:23 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Sounds more like a signal problem from your head unit. Either your cables are bad, or the amp is bad. Does your amp power up? If so, then the power &/or ground is not the problem, I wired my amp ground to the same spot (seat bolt) and didn't grind any paint off and it works just fine.
    Maybe try another set of cables? Or as stated before try another amp?
  18. Nov 20, 2010 at 8:23 PM
    kcrob1
    kcrob1 Choot It!
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Oh I looked over that part... Then I guess the deck is going to be the issue. May be a defective pre-out then
  19. Nov 20, 2010 at 8:24 PM
    NelsonTacoma
    Tucson, AZ
    ^^^^This, if not the cables or the amp.
  20. Nov 20, 2010 at 8:29 PM
    DSully72
    Daniel
    Appling, GA
    well like i said i tried my amp using a different cd player and my system worked fine... its not my amp... so it must be my rca cables or my cd player...
