Still in limp mode after 6 months
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GrampsTacoma23, Nov 1, 2022.
  1. Nov 1, 2022 at 6:08 PM
    #81
    GrampsTacoma23
    GrampsTacoma23 [OP] Just hit 100k Club
    Jeff
    N GA
    2010 Silver Tacoma Base 2.7
    DJM Lowering kit, All LED lights on entire truck and inside, wheels
    Actually i didnt lol that would kind of make sense though, im gonna attempt to clear codes and possibly order the air pump delete stuff because i dont need the emmisions crap anyways
    goforbroke123[QUOTED] likes this.
  2. Nov 1, 2022 at 6:15 PM
    #82
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Is the engine misfiring in limp mode?
  3. Nov 1, 2022 at 6:16 PM
    #83
    GrampsTacoma23
    Jeff
    N GA
    No its not ive checked that already
    Steves104x4[QUOTED] likes this.
  4. Nov 1, 2022 at 6:18 PM
    #84
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Do you have an exhaust header? No leaks?
  5. Nov 1, 2022 at 6:20 PM
    #85
    GrampsTacoma23
    Jeff
    N GA
    No its factory manifold, not sure how that leaking would cause limp mode
  6. Nov 1, 2022 at 6:22 PM
    #86
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    You’ve replaced the valve cover and spark plug tube gaskets at some point?
  7. Nov 1, 2022 at 6:28 PM
    #87
    GrampsTacoma23
    Jeff
    N GA
    No i havent but its all completely dry no oil in the tubes or outside the cover
  8. Nov 1, 2022 at 6:31 PM
    #88
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    A missing power feed explains all but the intake air temp sensor code (perhaps that one was set from disconnecting something while troubleshooting the other codes).
    If you look at the diagram I posted of 2A the power feeds for the A/F Heater relay (P0031), O2 heater (P0037), MAF sensor (P0102), and Air Injection Control Driver (P1613) come through it from the EFI No2 fuse.
    If there were also codes for the Purge VSV and EVAP pump I would more so suspect a problem on the wire from the fuse to 2A, but since those codes were not present I suspect the problem is in the junction at 2A itself.
  9. Nov 1, 2022 at 6:45 PM
    #89
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I knew this idiot, once that squished the rubber vacuum line from the egr to intake resonator under the bracket that holds the intake resonator to the valve cover instead of over the bracket disabling its ability to function (kind of like me). Just something to check. Hope you figure this out, soon. Good luck
    Jimmyh likes this.
  10. Nov 1, 2022 at 6:56 PM
    #90
    GrampsTacoma23
    Jeff
    N GA
    Honestly not sure its annoying as hell though lol
  11. Nov 1, 2022 at 6:59 PM
    #91
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    Maybe try some viagra. I hear it works great for "limp mode"
  12. Nov 1, 2022 at 7:03 PM
    #92
    GrampsTacoma23
    Jeff
    N GA
    If 10mg works for me ill throw a bottle in the TB
  13. Nov 1, 2022 at 8:59 PM
    #93
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
  14. Nov 3, 2022 at 6:30 PM
    #94
    GrampsTacoma23
    Jeff
    N GA
    Alright im back and have ran the codes again and attempted to clear again, still in limp mode but some codes are gone. Now just showing P0102(Mass Airflow Circuit Low), P0113(Intake Air Temperature Circuit High Input), P1613(Secondary Air Injection System Driver). Also on my data my air intake temp was stuck at -40 so id assume that means ny ait isnt working which is why im getting p0102 im going to order a new maf and order the Secondary Air driver because im pretty sure thats my issue. Id say now im no longer throwing parts at it since i was told on my scanner what parts where tripping but luckily 02 sensor codes are gone will update soon
  15. Nov 3, 2022 at 6:40 PM
    #95
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you check if you still have power on the Blue/White wire (Pin 5) at the secondary air injection driver?
    Also the Blue/White wire (Pin 1) at the MAF sensor.
    You also need to check the ground on the Brown wire (Pin 5) of the MAF sensor.
  16. Nov 3, 2022 at 6:48 PM
    #96
    GrampsTacoma23
    Jeff
    N GA
    Confirmed still have power and ground mafs are relatively inexpensive anyways
  17. Nov 3, 2022 at 6:50 PM
    #97
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    With the engine idling tap the mass airflow sensor lightly with the handle of a screwdriver and if the idle fluctuates the mass airflow is bad apparently. Don’t know if it’s true or not
  18. Nov 3, 2022 at 6:55 PM
    #98
    Mr. Excitement
    Mr. Excitement Well-Known Member
    J
    Custom floormats, fuzzy dice
    They make a special MAF cleaner too. I’ve done it on my Mini Cooper and a Mercedes’. But speak to someone smarter first. Haha
    Steves104x4 likes this.
  19. Nov 3, 2022 at 6:59 PM
    #99
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you verified with a test light and not just a meter? I'm still not convinced the MAF and SAIS Driver is bad, the IAT sensors in them almost never fail.
  20. Nov 3, 2022 at 7:19 PM
    #100
    GrampsTacoma23
    Jeff
    N GA
    Ill try that but that doesnt sound super trustworthy
