Still in wonderland as to my 96 Taco overheating
Discussion in '1st Gen. Tacomas (1995-2004)' started by MJMorlan17, Aug 8, 2017.
  1. Aug 8, 2017 at 10:03 AM
    MJMorlan17
    MJMorlan17 [OP] Member
    Matthew
    Las Vegas,Nv
    96 Tacoma 2WD
    Hello fellow Taco heads,and Im back again with a lot more knowledge due to idiots forcing me to get books and tools and dive in head first!Ok ,so,I had an overheating problem back when,turned out the head gasket was crushed on the exhaust side,pumping fumes into coolant equals hella hot! So,I got a new head kit,everything included,(head bolts,gaskets,etc,,)did the job myself,triple checking every step along the way!Turned the key after turning the last bolt,very proud of myself!One rainy night some five months later,look at my temp gauge,it is rising faster than the Rising Sun in Japan (pun intended)!Stop,open the hood,extremely hot top hose,cooler bottom hose.Changed the thermo in the morning,letting it cool over night!I never let it go red on the gauge!After that,all good for a couple of weeks,last night,gauge is climbing again.Pull over,let it sit over night ,going back to get it this morning.All the threads I have read! Ive checked and double checked all hoses,belts etc..Im having Kool Radiator here in Vegas check it today!Once again,everything is new,radiator,water pump,thermo,water inlet on the top hose,top and bottom hoses,belts!What in the hell could I be over looking!?!?!? Thanks in advance for your opinions!
  2. Aug 8, 2017 at 10:07 AM
    Clearwater Bill
    Billy
    Largo Florida
    Are we to assume you have no coolant loss?
    What driving conditions is the overheat happening under?
    You don't mention the cooling fan. Status of the fan clutch?
    But whatever, we're all just non-present guessers. The radiator shop should easily pinpoint your problem with a pressure test and infrared gun.
  3. Aug 8, 2017 at 10:22 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Replaced the radiator cap yet?
    kgt0001 and MrCrowntown like this.
  4. Aug 8, 2017 at 10:26 AM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    X2 on the cap. It's #1 part to verify
    EDIT: I wanted to add, is your EGR working correctly? It works to bring temps down in the cylinders, and I have seen a bad switching valve cause overheating conditions IE rising gauges, bubbling expansion tank etc
  5. Aug 8, 2017 at 10:27 AM
    tony2018
    tony2018 Well-Known Member
    Any work done to the head, or heads?
    ditto on radiator cap too
    water pump replaced recently with the proper gasket (yeah my 3.4L looks to have the original pump from 2002 because theres no metal gasket).
  6. Aug 8, 2017 at 10:38 AM
    MJMorlan17
    Matthew
    Las Vegas,Nv
    96 Tacoma 2WD
    New "everything,cap,radiator,water pump gasket,egr regulator,checked egr by applying vac,etc,,,
    MrCrowntown likes this.
  7. Aug 8, 2017 at 10:40 AM
    MJMorlan17
    Matthew
    Las Vegas,Nv
    96 Tacoma 2WD
    normal driving conditions,brand neww 188 dollar fan clutch also
  8. Aug 8, 2017 at 10:40 AM
    tony2018
    thermostat?
    So coolant is disappearing or leaking?
    If its disappearing than you probably need to get the head checked for warpage
  9. Aug 8, 2017 at 10:42 AM
    MrCrowntown
    Alyn
    Ky
  10. Aug 8, 2017 at 11:37 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Sounds like an air pocket to me.
  11. Aug 8, 2017 at 11:44 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    MrCrowntown[QUOTED] likes this.
  12. Aug 8, 2017 at 11:47 AM
    MrCrowntown
    Alyn
    Ky
    Great suggestion!
    I would also get a compression check out of the way
    otis24[QUOTED] likes this.
  13. Aug 8, 2017 at 12:43 PM
    MJMorlan17
    Matthew
    Las Vegas,Nv
    96 Tacoma 2WD
    Heading to Kool Radiator now.Compression check will be done to!Ill get back to you all soon for the details on that!
  14. Aug 8, 2017 at 12:48 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Is it the original radiator?
  15. Aug 8, 2017 at 3:59 PM
    miloaksrider
    miloaksrider Member
    SoCal
    03 Taco
    I'm agree w Mr crowntown. If you've check the usual and no luck check for exhaust in coolant. I will say this doesn't always cause coolant loss but usually does specially if you overheat it (in the red). I had similat prob on my 86 22R. Problem persiste even after new head, gasket, pump, radiator, tstat etc. Turned out to be hairline Crack in No. 2 cyl. Once I determined exhaust in coolant, off came the head. Filled block w tap water, let sit over night and a rust line in No. 2 appeared plain as day. Good luck. Peace.
  16. Aug 8, 2017 at 4:00 PM
    miloaksrider
    miloaksrider Member
    SoCal
    03 Taco
    Btw. I just did the head on my 04 2.7 w 229k. Running like a champ.
  17. Aug 9, 2017 at 12:00 AM
    MJMorlan17
    Matthew
    Las Vegas,Nv
    96 Tacoma 2WD
    Ok,so,after some time down at Kool Radiator,everything checks out ! Good compression,no exhaust being pumped into the coolant,coolant flow after thermo opens,hoses are fine,belts are fine,cap is fine,RADIATOR IS NEW,gonna jack it up in the morning and run it with the cap off in case there is an air pocket in the system,and will check the overflow tank and radiator daily for coolant level!Hopefully this over heating problem will end!Thanks for all of the input!
  18. Aug 9, 2017 at 8:13 AM
    Glamisman
    Glamisman Well-Known Member
    when you put the thermostat back in did you position the jiggle valve properly? On 4 cyl it is positioned at 12 o'clock for the V6's it is at the 6 o'clock position.
    You do have the heater core "in the system" and not bypassed I hope and if so the valve is installed correctly
  19. Aug 9, 2017 at 4:42 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Faulty gauge or temp sensor?
