Still Interested in Taco 5.7 engine swap
Discussion in 'Performance and Tuning' started by Blake, Jul 20, 2013.
  1. Jul 25, 2013 at 3:41 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  2. Jul 25, 2013 at 3:44 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    you the black taco i see around town with the front and rear off road bumpers and a lift?
  3. Jul 25, 2013 at 4:15 PM
    Blake
    Blake [OP] Well-Known Member
    Knoxville, TN
    2010 Doublecab TRD Offroad Supercharged
    OME Heavy Kit TRD Supercharger Borla Catback Exhaust
    Yes, mine is the black one...we just took the top off the back.
    Perhaps I didn't explain clearly, my son got my uber reliable 2010 Taco with TRD Supercharger, Catback, OME lift with heavy rear leafs, KMC wheels, Road Armor front and rear bumpers, and 285/75/16s...yeah, he better thank his lucky stars to have such a badass truck as a 16 yo.
    I want to build another (or have one built). If I can get another 50-75hp over what my black truck has, I think I'll be happy. The trick is I want it reliable, just like my other two blown Tacos have been.
    I guess I need to call URD to discuss exactly what I am looking for.
  4. Jul 25, 2013 at 4:23 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    I have seen you around a few times. mostly out in west knox/turkey creek area.
    and idk if the 5.7 would even fit in the 2nd gen engine bay. my brother has a 5.7 tundra and that engine is huge! quite a bit bigger then the 4.0, so idk if it would even fit.
  5. Jul 25, 2013 at 4:46 PM
    Hughesc99
    Hughesc99 Well-Known Member
    Derby, KS
  6. Jul 25, 2013 at 10:08 PM
    650H1
    Michael
    VA
    Yes it is
  7. Jul 26, 2013 at 3:39 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Yes, call URD and talk it over with Gadget. You might even be able to drive to his shop, accomplish the install, make some dyno runs and see exactly where the power lays before leaving.
    Honestly though, it doesn't sound like cost is a major concern here, you should also contact Allen Phillips Racing in Texas. They may have some experience in the engine swap using oem Toyota items, and if not can no doubt build HP also.
    PK
  8. Jul 27, 2013 at 4:31 AM
    Blake
    Knoxville, TN
    Spoke with Gadget yesterday, and got a good education. No longer interested in the 5.7, but I will definitely be adding a URD Supercharger Kit.
  9. Aug 1, 2013 at 6:45 PM
    colby8100
    colby8100 Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    I have a 2jz in my 01. While I'm doing my new bottom end rebuild we put a 434 in just for a quick race since I run a th400 trans. Just like the rest said a little fab experience and basic wiring and you can run anything you want. We also have a nitrous lq9 we're saving for a mustang. Stick with the Toyota engine if you do a swap.
  10. Aug 1, 2013 at 6:53 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Instead of a 5.7 I would consider a 4.7 swap which should fit but then you would have to get a harness for your electrical hookups. Would be a lot of work but def understand wanting a v8 in the Tacoma. Hell I wish they offered it. Sure you can get good horsepower out of the v6 tweaking it but its never gonna sound like a v8. 4.6 or 4.7 w a supercharger would be a hell of a combo in the Tacoma.
  11. Aug 2, 2013 at 5:57 AM
    colby8100
    Colby
    South carolin
    There are a lot if guys on forums that like to brag about swaps. A 4.7 is a great swap. I'm sure there is a guy on one of the Tacoma forums that could make you a plug and play harness for cheap if you don't won't to do it. Or you can buy an aftermarket ecu and harness and be able to tune it for any future mods.
