still misfires p0301
Discussion in '1st Gen. Tacomas (1995-2004)' started by boodacrf450, Nov 21, 2024.
  1. Nov 21, 2024 at 4:49 AM
    boodacrf450
    boodacrf450 [OP] Well-Known Member
    99 Tacoma 2.4L
    update I replaced iac valve cleaned maf sensor, plugs wires, and injector leak down test was good no leaks compression also good what should I check next I get random misfire on cylinder 1thanks for help
  2. Nov 22, 2024 at 10:34 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    If you search this forum on "P0301" you'll find quite a bit of info that will help you diagnose your problem. Be sure to clear your Check Engine indicator and see if the code returns before you put a wrench to the job.
