Still misfiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hspot, Apr 14, 2023.
  1. Apr 17, 2023 at 3:33 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Have to verify your mechanic did a compression test and leak down. Plenty of mechanics will throw parts at a problem hoping for it to be fixed. Not like it's their money.
    Usually you would be charged for the diagnostic, were you?
    HondaGM likes this.
  2. Apr 17, 2023 at 7:52 AM
    Hspot
    Hspot [OP] Well-Known Member
    2013 Tacoma AC
    Even driving on fumes all the time? I know that creates build up and gunk in the system. And when I googled it, albeit google answers..., it said a misfire could be a result?
  3. Apr 17, 2023 at 7:55 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    4cyl or 6cyl?
    SR-71A and HondaGM like this.
  4. Apr 17, 2023 at 8:03 AM
    Hspot
    2013 Tacoma AC
  5. Apr 17, 2023 at 8:11 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    They did replace the valve cover and spark plug tube gaskets… rright?
    HondaGM likes this.
  6. Apr 17, 2023 at 9:11 AM
    Hspot
    2013 Tacoma AC
    I'm not sure. I don't think they did anything to the valves. I got brand new injectors. I forget what it was, but if my engine was a certain type or size, I could afford to have the valves adjusted. If it were a different size, I would need brand new valves, as they couldn't be adjusted....I think that was the scenario?
  7. Apr 17, 2023 at 9:50 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The 2TR-FE uses hydraulic valve lash adjusters.
    You can’t adjust them manually. The engine oil pressure does it.
    They typically fail by sticking. When they do, they are usually accompanied by a ticking/tapping noise.
    BassAckwards and HondaGM like this.
  8. Apr 17, 2023 at 12:50 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    So, the black plastic cover with the Toyota logo on the top of the motor was never removed?
    HondaGM likes this.
  9. Apr 17, 2023 at 12:59 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Next step.
    Find a new mechanic.
    HondaGM, Steves104x4 and 12TRDTacoma like this.
  10. Apr 17, 2023 at 1:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That is the wrong answer entirely. You need a mechanic who is going to inform you on what they are going to do to test it and if you don't know what they are talking about, educate you in their methodology. Especially if you are paying.
    A mechanic who is throwing parts at a car in hopes of it fixing the problem without thoroughly testing it first (because there are always some cars that are absolute head scratchers despite testing) is a poor mechanic who should not be trusted for diagnostic functions.
    HondaGM, TnShooter and fourfourone like this.
  11. Apr 17, 2023 at 2:32 PM
    Hspot
    2013 Tacoma AC
    IDK. Like I said, they did diagnostics twice. I'm sure they checked all the above. I never knew to ask any of the above,as I am not knowledgeable in automotive stuff.
    HondaGM and Steves104x4[QUOTED] like this.
  12. Apr 17, 2023 at 2:34 PM
    Hspot
    2013 Tacoma AC
    Well I am quite sure they just don't throw parts at it and hope it works. This place is one of the most reputable shops in San Diego. Maybe I just don't know how to answer your questions.
  13. Apr 17, 2023 at 3:34 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
  14. Apr 17, 2023 at 3:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is this a place that offers free diag?
    12TRDTacoma and HondaGM like this.
  15. Apr 17, 2023 at 3:53 PM
    #35
    TnShooter
    Deogee
    STOCK
    If it was, it isn’t anymore.
    We’re $1,000 into it and it’s still not fixed.
  16. Apr 17, 2023 at 4:27 PM
    #36
    Hspot
    2013 Tacoma AC
    No, but the mechanic is a friend of mine from surfing. So he is taking care of me via the diagnostics since they can't figure it out, and I've been throwing a lof of money into it. I didn't pay for the last diagnostic, just $500 for the injectors, and $300plus for the labor.
  17. Apr 18, 2023 at 8:43 AM
    #37
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    How is it going?
    HondaGM likes this.
  18. Apr 18, 2023 at 9:21 AM
    #38
    Hspot
    2013 Tacoma AC
    Won't know details until Thursday at the earliest. I take it into the shop that day. As far as the misfire and startup issues....Unless I let my truck warm up completely before I start driving it, it will drive bad down the road, I can feel it bogging. But if I'm able to punch it during that initial time, it starts to run fine. Like I just needed to get some fuel running past something? IDK. But yesterday when I tried to punch it, it immediately jumped into the lowest gear off of maybe 10-15mph....probably cuz the new injectors? But it misfired again when that happened. Weird thing this time though....when I stopped my truck, then started it again, which usually fixes the misfire...I did not have to clear the check engine error. It just disappeared from my dashboard. I usually have to use my OBDII reader and clear the check engine message.
  19. Apr 18, 2023 at 9:24 AM
    #39
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    When the truck is idling does the tachometer needle move up and down a little or is it steady?
  20. Apr 18, 2023 at 10:48 AM
    #40
    Hspot
    2013 Tacoma AC
    Well, it definitely doesn't idle like it used to before all this. I guess it moves up and down a bit, not significantly though. It almost feels like the idling was the problem at first, cuz it felt like enough fuel wasn't getting into the system to start? But I would also think they would have looked at that too? I rev the engine to get more fuel into the system when starting it up in the morning for the first time.
