Still pulling right after alignment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aleriance, Dec 5, 2020.
  1. Dec 8, 2020 at 8:54 AM
    Myles G
    Myles G Well-Known Member
    Myles
    My cooper stt pros did the same thing
    I got UCAs and drove couple 100 miles and it stopped
    71tattooguy likes this.
  2. Dec 8, 2020 at 9:43 AM
    Cementoffroad
    Cementoffroad Well-Known Member
    Josh
    18 Cement OR
    When i went from my wildpeaks to ST Maxx, I immediately noticed the pull to the right.
  3. Dec 8, 2020 at 10:25 AM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    couldn't that rear toe being pos .24 and -.02 cause the crooked wheel? any difference between tires on toe will give a crooked wheel, I don't think it will cause a pull but not sure if that's a large enough difference though to cause a crooked wheel
    usually camber being off gives the pull but op's front camber/caster look good...I second the swap the front tires and see if it follows
  4. Nov 4, 2022 at 8:22 AM
    jvolek
    jvolek Active Member
    Houston, Texxas
    2019 Tacoma TRD Pro
    2019 Tacoma TRD Pro
    Nitto Terra Grapplers
    Replaced the factory tires days after purchasing the Tacoma, with Nitto Terra Grapplers, and began to slowly notice a pull to the right with hands off the steering wheel. Rotation, Balancing, and Alignments did not resolve the issue. Just recently replaced the Nitto's with some new Toyo AT III's and the pulling to the right issue is gone. The Nitto's clearly had some tracking issue, always believed it was an issue with the Tacoma, but clearly, it had been an issue with the Nitto's from the beginning.
  5. Nov 4, 2022 at 8:27 AM
    99GC8
    99GC8 Well-Known Member
    Dwight
    Fort Collins
    2015 Taco supreme
    Nittos and Toyos both have issues pulling try swapping the front tires side to side. Also if you could post a picture of your alignment specs that would help.
  6. Nov 4, 2022 at 8:44 AM
    vhinojosa4735
    vhinojosa4735 TXTaquito
    Vince
    Corpus Christi, TX
    2010 TRD OR Double Cab Taco 4x4
    2010 TRD Off-road Double Cab 4x4 McNeil Racing Fiberglass 3rd gen conversion all the way around. 4.56 nitro gears, Doug thorley long tubes, TRD exhaust, 37” Toyo M/T’s on 17x9 Method 312’s (5),Dirt King +3.5 Long Travel up front with 2.5 kings all the way around, durobumps up front, Alpharex headlights, Baja Design Fog lights, SR20” rigid bar, Demello Offroad Baja bumper, Dakar HD rear springs, prinsu rack, taco bed mat, AL off-road Trailgate,rci skid plate, full sound system, katzkin all leather seats, 10 pro comp rock lights, switch pro 8 switch setup, on board VIAIR compressor, smittybuilt 9k winch, total chaos cam tab gussets and spindle gussets.
    Swap your front two tires to eliminate the tire pull accusation.
  7. Nov 4, 2022 at 9:47 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    mine is the same from the factory. if i hold the wheel perfectly straight, it veers to the left. exactly the same even after tire rotation so don't think it's the tires. maybe the rear axle is slightly crooked?
