Still runs rough
Discussion in '4 Cylinder' started by Jdb166, Mar 29, 2014.
  1. Mar 29, 2014 at 9:17 PM
    Jdb166
    Jdb166 [OP] New Member
    New York
    Clean red 1989 4x4 22r
    I changed the egr valve and plugs and wires . Still runs rough when at idol !! Anyone have any ideas wht
  2. Mar 29, 2014 at 9:18 PM
    Jdb166
    New York
    It's a 1989 4x4 pickup 22 r 110k
  3. Mar 29, 2014 at 9:26 PM
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    Did you check the air filter for blockage?
    Or maybe a vacuum leak.
    Is there a CEL? Need more info?
    Could even be something like water in the fuel.
  4. Mar 29, 2014 at 9:46 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Valve adjustment maybe, but at 110k it should be okay.
    That's super low mileage for a truck that's 25 years old. Might be varnish or corrosion in the fuel system. Might need a complete disassembly and cleaning of the throttle body and injectors.
  5. Apr 18, 2014 at 2:37 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    +1 on the air leak. get a can of wd-40 and spray around the vacuum lines. If the idle rises or falls, change that line. Did you inspect the rotor and cap when you changed the wires?
  6. Apr 18, 2014 at 9:56 PM
    Jdb166
    New York
    Yes that is correct !!
