still scrubbing on 35's
Discussion in 'Suspension' started by captainsmeby, Jan 18, 2014.
  1. Jan 18, 2014 at 5:45 AM
    captainsmeby
    captainsmeby [OP] New Member
    4x4 tacoma blue
    6" rough country lift
    i recently put a rough country 6" lift on my tacoma and a set of 35X12.50x20r, and its still scrubbing when i flex and turn. I've cut the fenders as much as i can, does anyone have a practical suggestion?:confused:
  2. Jan 18, 2014 at 5:49 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    What have you cut? And cut/beat more.
  3. Jan 18, 2014 at 5:49 AM
    Large
    Large Red
    Where are you rubbing?
  4. Jan 18, 2014 at 5:51 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  5. Jan 20, 2014 at 4:15 AM
    captainsmeby
    4x4 tacoma blue
    ive cut all the fenders and plastic out of the way so now im only scrubbing if i flex and turn or, flex hard. ive only noticed scrubbing on the driver side cab mount, not sure why its only one side.
    I still have the stock upper control arms, and stock front shocks.
    could possibly go with the belstein 5100 adjustable shock to stretch another inch out of the lift.
  6. Jan 20, 2014 at 4:18 AM
    Delmarva
    Tucson, AZ
    You need to do a cab mount chop
  7. Jan 24, 2014 at 10:25 PM
    Milehightaco007
    Milehightaco007 Well-Known Member
    Sean
    Aurora, CO
    08 TRD Sport SWB
    6 inch lift on 37s ARB and winch. home made sliders
    I have the same lift as you and you can not go any higher without longer cv there and angled just like a Tacoma that has a 3inch lift so you are going to just need to cmc or get some UCA and bring the tire forward a little and see if that works I know I clear a 12.5 tire just fine and im going to clear my 13.5 fine but I have done CMC and a have -12 offset on wheels and run 1.25 inch spacers and my wheels are 17x9
  8. Jan 24, 2014 at 10:32 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    wheel spacers make rubbing worse
  9. Jan 25, 2014 at 12:22 AM
    Milehightaco007
    Sean
    Aurora, CO
    08 TRD Sport SWB
    didn't for me it rubbed more on the plastic if that's what you mean but I don't need them to clear 12.5 wide tires but will for 13.5 wide and I will still have about a inch of space between the tire and the UCA
  10. Mar 24, 2014 at 5:23 AM
    captainsmeby
    4x4 tacoma blue
    ill be doing the cmc here in a couple weeks ill post an update to y'all know how it goes.
    also will changing my UCA's alone increase or decrease my wheels range of travel
