Still some play after replacing front wheel bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by yota1370, Oct 22, 2017.
  1. Oct 22, 2017 at 6:36 PM
    yota1370
    yota1370 [OP] New Member
    David
    1996 Toyota Tacoma
    complete rebuild
    Need some help with my 1996 Tacoma 4x4 with manual locking hubs. I just replaced my front wheel bearings. I used a 20 ton press and when I got it all back together there is still some play from moving the wheel up and down. How much if any play should there be?
    Thanks for any help.
  2. Oct 22, 2017 at 9:49 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Oct 22, 2017 at 10:26 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Shouldn't be any play.
    tcBob likes this.
  4. Oct 22, 2017 at 10:27 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Is the movement in the wheel bearing or the balljoints?
    wilcam47 likes this.
  5. Oct 22, 2017 at 10:38 PM
    Bishop84
    Bishop84 Well-Known Member
    Loose wheel bearings have a distinct sound when you hit the tire.
    Also the axle will shift up and down when checking for play, separate from the knuckle.
    tcBob likes this.
  6. Oct 22, 2017 at 10:47 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    If the bearing was pressed in with the old hub it could be the hub was nicked by a cut off wheel when the old bearing race was split..
  7. Oct 22, 2017 at 10:48 PM
    eon_blue
    Azusa, CA
    Bad ball joints can cause some play in the wheels
  8. Oct 23, 2017 at 11:20 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    As your post implies,,your grabbing the hub mounted wheel and tire on each side at the top and can pull up, and then let it fall on its own weight and there is play??. If that's the case,,there shouldn't be any play with new bearings. It shouldn't move up and down at all. I think your problem might be somewhere else.
