Still throwing same code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jc4x4, Feb 12, 2020.
  1. Feb 12, 2020 at 6:41 PM
    Jc4x4
    Jc4x4 [OP] Well-Known Member
    Jordan
    Maine
    2014 4wd SR5
    I have a 2014 Tacoma v6 that has decided not to start. Has been running fine then all of the sudden after work today it did not want to start. Thought it was the battery so tried to jump it and eventually got it running. Ran fine on the way home, but the check engine light came on and my traction control light came on and I could not turn off. Used code reader and got P0355 crankshaft position sensor 'a'.
    Truck also has little to no power when off could it possibly be something else or is that a symptom of the crankshaft?
    Tried to find a video or something to show me how to replace and I could not find. Can someone point me in right direction?
    Thanks for help
  2. Feb 12, 2020 at 8:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Feb 13, 2020 at 12:01 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Bad news its under the tensioner pulley assembly mounting bracket and the alternator has to come off then unbolt and move the AC compressor over to unbolt the tensioner assembly. Saw it under there when doing tensioner so look at the pics and you will see it. You have to pull the drivers side wheel off to get into those bolts so need extensions and a few hours.
    https://www.tacomaworld.com/threads...-alternator-replacement.643020/#post-22311196
  4. Feb 13, 2020 at 1:45 AM
    Jc4x4
    Jordan
    Maine
    2014 4wd SR5
    Thank you both, sounds like more than I am going to do laying in the snow.
    Raylo and DG92071 like this.
  5. Feb 15, 2020 at 10:36 AM
    Jc4x4
    Jordan
    Maine
    2014 4wd SR5
    Camshaft sensors and crankshaft sensor have been changed. Also put a new battery in and still has same p0335 code. Any ideas?
  6. Feb 15, 2020 at 11:10 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    A weak starter can trip this code. Look into that.
    Jc4x4[OP] likes this.
  7. Feb 15, 2020 at 11:13 AM
    Jc4x4
    Jordan
    Maine
    2014 4wd SR5
    I saw that as well but it starts up great. Never had an issue with that.
  8. Feb 15, 2020 at 11:14 AM
    muddog321
    FL
    Some other posts mention that they had a remote start installed and that was related to the issue and saw you were from Maine.
    I have never had this code or issue so could only search the P0335.
    Follow the sensor wires up and make sure no critter has chewed thru them as they were seeking a warm place.
  9. Feb 15, 2020 at 11:18 AM
    Jc4x4
    Jordan
    Maine
    2014 4wd SR5
    Forgot to mention above that truck is running great now that parts have been replaced. Just the code keeps coming back.
    Also do not have remote starter @muddog321
  10. Feb 15, 2020 at 11:28 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    I might have missed it, but did you actually use the scanner to clear the code or are you just waiting for it to clear? This may be one of those codes that gets stored in the ecm
    wilcam47 likes this.
  11. Feb 15, 2020 at 12:09 PM
    Jc4x4
    Jordan
    Maine
    2014 4wd SR5
    Tried to clear with scanner. Goes away then comes back like 30 seconds later
  12. Feb 15, 2020 at 12:38 PM
    maxtherat
    Inland Northwest
    Sounds like some kind of hard code. Maybe something a dealer had to clear? My wife’s old car threw a code (forget the number) and it would instantly come back. It ended up being the damn computer and I had to buy a refurbished one. Hope someone with more experience in this can help you out
  13. Feb 15, 2020 at 12:39 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I’ve read some codes need the battery disconnected for say a couple hrs so the computer forgets them?
    Not sure if this is the case but I saw it when throwing 02 codes on my Tacoma.
  14. Feb 15, 2020 at 1:45 PM
    Jc4x4
    Jordan
    Maine
    2014 4wd SR5
    I will try this
  15. Feb 16, 2020 at 12:14 PM
    Jc4x4
    Jordan
    Maine
    2014 4wd SR5
    Left battery unplugged for a few hours. Code went away but came back quickly. Guess I will see if it is something dealer can get rid of
  16. Feb 16, 2020 at 12:18 PM
    Bishop84
    Bishop84 Well-Known Member
    Could be sludge on the tone ring. A stretched timing chain is a different code.
    I would say the next step is an osciloscope.
    BUT
    I've seen a failing battery cause this. Even if it starts it and runs ok. The freeze frame on the code is usually low.
    Best wishes.
  17. Feb 16, 2020 at 12:43 PM
    Jc4x4
    Jordan
    Maine
    2014 4wd SR5
    The battery is brand new so I dont think it is that.
    Not sure what a tone ring is?
  18. Feb 16, 2020 at 1:36 PM
    Bishop84
    The ring that the crank shaft sensor reads.
    The battery that caused my p0355 code on the highlander was .3 months old and only had 8000km on it. Unlikely but sharing anyway.
    Jc4x4[QUOTED][OP] likes this.
  19. Feb 16, 2020 at 2:13 PM
    Jc4x4
    Jordan
    Maine
    2014 4wd SR5
    Thank you will try that
    Gm84 likes this.
  20. Mar 24, 2022 at 12:29 PM
    Gm84
    Gm84 Member
    Gerson
    2015 sr5 taco dclb
    Any luck?
