STiLL WILL's[MATT] 2013 Super(charged) White DCSB T|X Pro
Discussion in '2nd Gen. Builds (2005-2015)' started by STiLL WILL, Mar 3, 2013.
  1. Mar 13, 2015 at 2:45 PM
    #921
    STiLL WILL
    STiLL WILL [OP] MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2021 Tundra TRD Sport 4wd
    Yes, I sold my '13 Taco. :'(
    Today I basically added another 15hp to the tires, AT LEAST.
    You never know when you'll need to recover yourself or fellow mall crawlers out at the local shopping center parking lots.
    I bolted on these $200/pair d-ring shackles made from NASA grade unobtainium to my Brute Force Fab bumper. Super strong and add tons more horsepower. Butt dyno now says I can smash Corvettes from a roll to 130mph.
  2. Mar 20, 2015 at 10:20 AM
    #922
    Spatial K
    Spatial K Well-Known Member
    Wyoming
    2015 AC TRD/OR 4x4 V6 MT
    TRD Quickshifter, Icon Ext Travel Front and Rear / Camburg BJ UCAs, OME Dakars, TRD Faux Beadlock Wheels, BFG AT KO2 285/75
    You're the only one i've found so far that is running the fauxlocks with spacers. Im trying to decide on a size to get. I'm running 285/75 BFG AT KO2s and 3'' of lift. I mocked up some 3/4'' spacers on mine and it looked like they stuck out more than yours do but you're running a full 1.25''? They really don't seem to stick out that much. Can I trouble you for a pic from the rear and or measurements? Thanks! Sweet build!
  3. Mar 20, 2015 at 11:21 AM
    #923
    STiLL WILL
    CA
    They poke out wellll past the fender flares. :)
    No way a 3/4" spacer will poke more than the 1.25" ones I have now---with the same wheel and same tire size. Might just be the angles of the pictures. For the record there was a bit more clearancing in the front that needed to be done to run 285/75r16's in the front in addition to the usual "cab mount chop" to help give the 33's and spacers enough room.
    Do the pics on the 1st post of my build thread not show it? Have a look again, otherwise, I've got pictures spread throughout this thread with rear shots and the width. ;)
  4. Mar 20, 2015 at 11:00 PM
    #924
    Spatial K
    Wyoming
    Yeah, it's hard to tell from pictures. I can't decide in sliders either for the same reason. In hindsight, would you do 1.25s again or other?
  5. Mar 21, 2015 at 7:43 AM
    #925
    STiLL WILL
    CA
    Spacers could be removed at anytime so I guess I am more than happy with them. In hindsight, I'd have no hesitation running them again.
    Here are the best shots of "width" I could find in this thread:
    Front
    Rear
    IMG_20131202_104519-picsay_1_zpsdfbdf5b0_0d40da57bbcd7dfc8474a5c2d1ce1c37db598fd1.jpg
    Both pics, look at where the fender is in reference to the tires. Bit of poke. :)
  6. Mar 21, 2015 at 8:30 AM
    #926
    ThomasMore66
    Dallas/Fort Worth & Durango
    Talk to me about those front flaps. The stock ones are way to large, but practical.
  7. Mar 21, 2015 at 8:54 AM
    #927
    STiLL WILL
    CA
    These ones are practical but not so much in protecting as mud flaps...but as protection for what they're covering that needed to be clearanced for 33's +spacers.
    Post #419 my friend ;)
  8. Mar 21, 2015 at 9:11 AM
    #928
    Spatial K
    Wyoming
    Thanks for reposting the pics. I did go back over your thread a few times and that first pic shows it the best I think. Now I just need to make a decision. Thanks for your input.
    Loving the mud nubs btw.
  9. Apr 18, 2015 at 9:00 AM
    #929
    HWYCAT
    HWYCAT Member
    ANDY
    CALIFORNIA
    TACOMA-LONG BED
    LOTS
    Almost as nice as my truck....Very Sweet Ride!!!!
  10. Apr 18, 2015 at 9:00 AM
    #930
    HWYCAT
    HWYCAT Member
    ANDY
    CALIFORNIA
    TACOMA-LONG BED
    LOTS
  11. Apr 18, 2015 at 10:02 AM
    #931
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  12. Apr 18, 2015 at 10:36 AM
    #932
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  13. Apr 18, 2015 at 9:39 PM
    #933
    1truckdriver
    1truckdriver BRO
    Daniel
    Rancho Cucamonga, Ca.
    '15 DCSB Off Road 4x4 SuperWhite
    TRD SuperCharger SCS Rays 10
    You are the reason why I went with a SuperWhite . I absolutely love what you've done with your built . Much props to you man!
  14. Apr 19, 2015 at 1:10 AM
    #934
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Andy...did you start a new thread?? To change your Call Sign?
  15. Apr 19, 2015 at 1:54 AM
    #935
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Quoted the longest post to say his truck is "almost as nice as your truck," and then repeated it again right after??
  16. Apr 19, 2015 at 7:18 AM
    #936
    Over da Hill
    Over da Hill "Roads...where we're going we don't need roads"
    Johnny
    SoCal
    15 Black Taco 4WD DC SB SC
    Supercharger, Icon stage 3 suspension, Pelfreybilt Armor, All-Pro Sliders & Leaf Pack, 17 inch Black Rhino Sidewinder wheels, 33 inch Toyo tires, Rigid Lighting, SPod,
    Very nice job!
  17. Apr 19, 2015 at 7:16 PM
    #937
    STiLL WILL
    CA
    Hmm. Thanks??
    x2
    LOL
    Wow, thank you! Any questions you have man shoot me a PM! :)
    Lmao
    ^^^^^i wanna seeeeee
    Thank you!!!!
  18. Apr 19, 2015 at 7:17 PM
    #938
    STiLL WILL
    CA
    *sigh* I just wish my truck was as nice as HWY CAT's. :(
    pat's taco likes this.
  19. Apr 19, 2015 at 7:35 PM
    #939
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Haha he must love his truck
  20. Apr 19, 2015 at 7:41 PM
    #940
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    :notsure::notsure:
    Lol
