Still wondering about 285/75/16's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomwilson74, Oct 26, 2012.
  1. Oct 26, 2012 at 11:49 AM
    tomwilson74
    tomwilson74 [OP] Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    Been on the forum since March and I have mainly read that this size tire will rub if I don't do some cutting. I just saw a guy at Wallyworld and he has a leveling kit with 285's. He turned the wheel both ways and has plenty of clearance. I have an OME 3 inch with aal and don't do much wheeling. I plan on putting 285's on this spring or a little earlier. I'll just keep my fingers crossed?.
  2. Oct 26, 2012 at 11:56 AM
    eric3187
    eric3187 Well-Known Member
    you can get by without cutting the cab mount if you have it aligned so it pushes the wheel forward, may have to trim the fender flares a bit.
    i have OME suspension as well and i rub on the drivers side, but clear on passenger side by maybe 1/4" but i go wheeling once a week so i will be trimming a bit to clear when aired down
  3. Oct 26, 2012 at 12:14 PM
    tomwilson74
    Tom
    West Virginia
    The guy I talked to had an '08. He did no trimming at all, still had room even with the wheel turned. He didn't have mud flaps on his truck though.
  4. Oct 26, 2012 at 12:17 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    He might have had older tires cause with 285's your going to rub if you dont do some minor trimming. I have a 3" lift and I still rub the cab mount a little bit at full lock. Trimming is super easy....nothing a dremel cant fix.
