still wont start
Discussion in '1st Gen. Tacomas (1995-2004)' started by pig#, Mar 11, 2024.
  1. Mar 11, 2024 at 12:34 PM
    pig#
    pig# [OP] Member
    just changed my plugs wires and coil packs still wont start engine turns over no action is there a basic step i need to to follow to check for spark is there a fuse in the ignition system i could check help please
  2. Mar 11, 2024 at 1:12 PM
    Tyren
    Tyren Active Member
    Tyren
    2015 Toyota Tacoma
    Maybe your fuel system(fuel pump or fuse)?
  3. Mar 11, 2024 at 1:18 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Are the spark wires routed correctly? Thats where I'd start.
  4. Mar 11, 2024 at 1:21 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    What year? What engine?
  5. Mar 11, 2024 at 1:58 PM
    Sklar
    Sklar Well-Known Member
    Skylar
    2003 Tacoma Double Cab 3.4L
    200K and counting.
    Did you check all your grounds? noting unplugged? I did this work and missed plugging in my MAF and got a no start. I was good to go when I did a run about looking for missed connections.
  6. Mar 11, 2024 at 6:06 PM
    Glamisman
    Glamisman Well-Known Member
    Does the Check engine light come on when you turn the key to the ON position?
  7. Mar 11, 2024 at 6:12 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Scan for codes/ check flash codes first then report back
  8. Mar 11, 2024 at 6:50 PM
    pig#
    pig# [OP] Member
    check light is on engine turns over wont fire
  9. Mar 11, 2024 at 6:55 PM
    joba27n
    Nolan
    Alberta
    Are there any codes stored?
  10. Mar 11, 2024 at 7:58 PM
    Benzoil04
    Benzoil04 Well-Known Member
    Eastern WA
    2000 3.4l 4x4 5spd, 1997 3.4l 4runner 5spd
    Bad fuel maybe? Change fuel filter?
  11. Mar 11, 2024 at 8:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Spay just a small puff of starting fluid in the intake when cranking the engine.
    If the engine tried to fire, it’s got spark. And you need to check fuel.
    If the engine doesn’t fire.
    Pull the coil out, unscrew the spark plug, and stick it in the coil. (Leave coil wires hooked up)
    Ground the plug on the engine block/manifold……
    Look for spark.
    joba27n likes this.
