Stink-bug stance - what would you do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kingston73, May 16, 2011.
  1. May 16, 2011 at 7:46 AM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    So I've decided to get rid of my heavy leer bed cap and replace it with a tonno. I have a 1.5 inch AAL in the rear and stock springs with Bilstein HD's up front. Before I took the cap off it sat nearly level, maybe a half inch high in back, but now that the cap's off it's noticably higher out back, not terrible but it looks kinda funny to me. I drive 99% highway and put the AAL's on because the stock springs sagged with the cap. My question is: what would you do?
    I figure I have one of 4 options:
    1. Leave it
    2.Install new 5100's up front - if this option what should they be set at? Also, if this option can I keep stock springs? (160,000 miles on them)
    3. Take out the AAL's
    4. Add a small spacer to the front - if so what size?
  2. May 16, 2011 at 8:52 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Add Bilsteins up front. Not sure what they should be set to (measure the aft vs the front and set them to the difference I guess). Keep the AAL in as it will help with axel wrap among other things.
    Im about to get Bilsteins on all four corners and PM'ed Dan about a possible group buy from Wheelersoffroad.com (including OME coil overs). If you have the money, Bilsteins front and aft and some OME 881 coil overs cost ~$500. And with the group buy, hopfully less.
  3. May 16, 2011 at 9:47 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I just solved this very same problem yesterday. I had an AAL in the back and it caused my rear to be 2 inches higher than the front one stock billisteins and stock coils. Just billie 5100s will NOT raise your front. You need a new strut (i got OME 90004s because the billies were back ordered) and 881 or 882s. I went with 881s
    The 881s are the same length as the stock coils but stiffer, your it holds your trucks weight 1.25-1.5" higher (or might be 1.5" to 1.75") and the 882s, if im not mistaken, are the same stiffness of the stock springs but longer than them.
  4. May 16, 2011 at 11:16 AM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    If you get the 5100,s set the notch to the middle which will give you about 1.5 inch lift up front. Not sure what the above post is saying that the 5100's wont lift your truck at all. Your stock springs will be fine also. I have my 5100's with springs that had 180k on them. I've attached a couple pics of my truck. It has a little squat to it because of my shell. Its stock leafs in the back.
  5. May 16, 2011 at 3:07 PM
    x2468
    hmmm, I was under the impression that the spring was the compression force and the oil/gas strut was purely rebound. In which case the height of the truck could only be changed by the spring tension or spring height being increased. I thought the adjustability of 5100s was merely so that it could be combined with taller springs of the owners preference. that was was Dan at wheelers off-road was explaining to me one time.
  6. May 16, 2011 at 3:10 PM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I know 5100's are the best way to go, but how bad would a 1 inch spacer be instead? I went out and measured from top of tire to bottom of wheel well, the front is about 7 and the rear is about 9, so an inch to 1.5 inches would set things back to about what they were when new from the factory.
  7. May 16, 2011 at 3:10 PM
    RecklessTaco
    RecklessTaco Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 35x12.50-17General Grabbers on 17x9 Black MB Wheels rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    Misinformed! If he is at stock height in the front Then the 5100's will work fine! they were designed to give anywhere between o-2.5 inches of lift up front. So im pretty sure they will work fine for him!
  8. May 16, 2011 at 3:11 PM
    mikracer
    San Luis Obispo, CA
    By going up the notches, you increase spring tension. You can also get the taller spring and leave the clip at the lowest notch. The benefit to getting a taller spring is you get a little nicer ride because the spring isnt compressed already. Running a stock spring at the middle notch isnt too bad for me and I daily drive my truck. If you only want to level your ride and not do anything serious in terms on off roading, etc, stock spring is the way to go since you can save a few hundred and not buy new springs.
  9. May 16, 2011 at 3:14 PM
    RecklessTaco
    Topaz Lake, Nv.
    A 1inch Top plate spacer will give you 2inches of lift just FIY! If you are only looking to raise the front 1 Inch then i would go with 1/2 inch top plate spacer! Toytec has them on there site
  10. May 16, 2011 at 3:16 PM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Good to know, thanks for that!
  11. May 16, 2011 at 3:21 PM
    x2468
    Damn, that sucks. for the longest time i had front OME 90004s and i didn't install them because i didn't have the time or money to get 881s. I would have put the stock spring on them.
    So wait. both the shock and the strut work togethor for propper compression... alright... how does the sturt produce upward force on the trucks weight? with an internal oil baithed spring?
  12. May 16, 2011 at 3:44 PM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I've been looking at installation instructions and it looks like even with the spacer I still need to take the strut apart? I was thinking I'd be able to just take it off, set the spacer in place, and reinstall. If I need to take the strut apart and compress the spring and all that, seems like it's stupid to put a spacer in when I can replace the strut itself with a 5100.
  13. May 16, 2011 at 3:56 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Exactly! Go for the 5100's. And while your at it, get some 5100's in the rear. Heck, through in some OME 880's (or 881's for a stiffer/taller ride)!
    If you dont do it right the first time, dont do it at all :D.
  14. May 16, 2011 at 4:21 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    X2. I looked at spacers for a bit, but eventually went with the 5100s. I have stock leafs in the back so I just went to the middle setting for about a 1" lift. The rear is still higher, but it looks a lot better. I thought 2.5" would be a bit much (for me). The front feels firmer, but not harsh or stiff.
  15. May 16, 2011 at 9:09 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    x3.
    x2
