Stipped two bolts -- now what?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pontoon, Nov 6, 2016.
  1. Nov 6, 2016 at 9:14 PM
    pontoon
    pontoon [OP] Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    So, I was replacing a couple gaskets where the transfer case shifter meets the transfer case (4 bolts). I was torquing them to the specified torque using a torque wrench, but two of the bolts stripped. I'm guessing I was torquing at an odd angle and the torque wrench wouldn't click, or someone had previously stripped the bolts and that was the cause of my leak. In any case, how do I repair the differential which is now stripped out? Also one of the bolt heads actually snapped after stripping the differential, which sucks. I'm guessing I can get the stripped bolt out with a vice grips but we'll see. The bolt is: 7t (marking on head) 8mm diameter 25mm length 1.25mm pitch hex head. Should I tap new threads? If so what diameter should I use? It looks like Toyota bolts go from 8mm to 10mm, not sure if I can go up to 10mm.
  2. Nov 6, 2016 at 9:42 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The TC is aluminum, so it doesn't take much to over-torque.
    Should have been 13 ft-lbs (according to the FSM).
  3. Nov 6, 2016 at 9:45 PM
    pontoon
    I had it set a hair under 20 ... Maybe I stripped it myself, but in any case, how can I fix it?
  4. Nov 6, 2016 at 9:52 PM
    tan4x4
    Rick
    Folsom, CA
    Wish I could help you, but I've never had to deal with this.
    Try googling. There's likely some youtube videos for details on this repair.
  5. Nov 7, 2016 at 12:33 AM
    pontoon
    I ordered 12mm long 8mm diameter 1.25mm pitch helicoils (it's an 8mm diameter bolt, so that follows the 1.5x rule). Hopefully this works alright I preferred the idea of drilling it out and tapping it with real threads, but I'd rather use the same size bolts if I can help it.
  6. Nov 7, 2016 at 1:28 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I think on something that is effectively just an oil seal your repair will be more than adequate. :)
  7. Nov 7, 2016 at 9:03 AM
    pontoon
    One other question: if I plug up the large hole the shifter goes in, will the metal shavings from drilling fall into the transfer case or not? Basically I'm wondering if the bolt holes end in metal or the air of the transfer case?
  8. Nov 7, 2016 at 9:06 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Dry threads? If using anti-seize or if there's any moisture/oil your torque measurements are gone. The paperwork with your torque wrench should warn you only count on it for dry clean threads.
    Markcal likes this.
  9. Nov 7, 2016 at 9:17 AM
    tan4x4
    Rick
    Folsom, CA
