stock 08 2tfe 4wd. towing cross country
Discussion in '4 Cylinder' started by scrapedface, Mar 6, 2009.
  1. Mar 6, 2009 at 9:11 AM
    scrapedface
    scrapedface [OP] Well-Known Member
    vacaville, ca
    2008 2.7 liter 4wd tacoma
    ipod charger and aux cable, scanguage 2, wet okole seat covers, 35% tint, toytec ultimate set at 2.5"
    im towing cross country and i was wondering what is the maximum i can safely tow from shore to shore? i know the max tow capacity on my truck is 3500. but im going over two mountain ranges and driving almost 3000 miles. also im gonna be towing a utility flatbed trailer. what is the best way to keep everything dry without having tarps ripping off? if get rid of a lot of junk the smallest amount i can tow is about 2000lbs including the trailer. also my car comes standard with automatic overdrive. i heard towing kills ur overdrive. does this mean i have to keep it out of 5th gear?
  2. Mar 6, 2009 at 9:36 AM
    wawireguy
    wawireguy Well-Known Member
    Check your manual but most trucks should not tow with OD engaged.
  3. Mar 6, 2009 at 12:47 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    As long as the transmission stays in 5th you are not hurting it. When it hunts back and fouth between 4th and 5th you are building up too much heat and should leave it in 4th.
    Driving on the interstate on flat land you can use 5th. If there are any kind of hills you'll need 4th. You will not hurt anything but your gas mileage using 4th.
  4. Mar 6, 2009 at 1:27 PM
    scrapedface
    vacaville, ca
    can this truck handle 2000lbs cross county over 2 mountain ranges?
  5. Mar 6, 2009 at 1:29 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I don't see why it could not.
  6. Mar 6, 2009 at 1:32 PM
    scrapedface
    vacaville, ca
    sweet. so whats the best way to keep everything dry thats loaded on to a utility trailer? i got a tarp but i bet it would rip.
  7. Mar 6, 2009 at 2:06 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Ok here the deal.. these truck are underrated for towing...
    So going to 3500 is not a big deal. yes hills will suck, but you can go 35 like the truckers do.
    Do not expect to drive 80 and 100 with a trailor.. Cops are out to ticket you for that.
    Be safe..
    Second I would buy good quailty tarps, then buy low end spider nets.
    Raps of the gear good and tight with straps and what not.
    THen cover it with Spider netting. To prevent the flapping.
    Ok Spider netting is a term more than a type or brand.
    Use lots of bungy cords and straps to get it right.
  8. Mar 6, 2009 at 2:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What makes you think they are "Underrated" for towing??
  9. Mar 6, 2009 at 2:34 PM
    scrapedface
    vacaville, ca
    thanks for the advice ubermx
  10. Mar 6, 2009 at 7:22 PM
    tex
    tex Well-Known Member
    Fort Worth, TX
    2006 V8 Sport 4Runner
    Instead of tarps try using rubermaind boxes. I am not sure what you are putting on the trailer but its an idea if its not a few large items like furniture.
  11. Mar 12, 2009 at 10:58 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    Here in Minnesota we haul lots of boats, big and small. I've never considered 'towing capacity' an issue before. If it'll move it..it'll work!. Granted , you've gotta consider handling when you drive, and know the limitations, but this little 4 cyl will move a bunch of weight and do it well as long as you are conscious of the light weight of the truck and drive accordingly.
  12. Mar 13, 2009 at 5:25 AM
    JDCPA
    Jim
    SW FL
    Just because a truck will move something is not valid confirmation that you should do it. A significant element of the tow capacity is the ability of the brakes to stop the load in an appropriate fashion. If you exceed the rating you are likely to have problems in a panic stop.
    If you are using it to move something across a yard, not on the road, you are probably OK using the "if it moves" criteria. Otherwise please warn me before you venture out on the highway. I want to make sure I am completely out of your way.
  13. Mar 13, 2009 at 10:37 AM
    ubermx5
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    What makes me think Toyota underrated there trucks.
    Well for 1. I have pulled over the 3500 LBS many times with no real issues.
    The trucks can take it... But this is not for everyone.
    3500 is the safe max.. the motor, brakes and tranny can take it.
    Over that yes, things get tricky...
    Also do these Automatic have 5th gear?
    i know a manual tranny does...
    When ever towing also disable OD.
    never use 5th gear... unless you are not stressing the tranny.
    4th gear is fine.. you will get 8 to 13 MPG no matter what gear when towing 3500 LBS.
