Stock 16” rims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maffoo, Oct 20, 2020.
  1. Oct 20, 2020 at 12:53 PM
    maffoo
    maffoo [OP] New Member
    2013 tacoma
    I have a 2013 Tacoma. Has anyone mounted 285-75r16 on stock rims? Where there any problems or concerns with rubbing or them being too large? Thanks.
  2. Oct 20, 2020 at 12:56 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I believe that without spacers, the tire will rub the control arm.
  3. Oct 20, 2020 at 7:54 PM
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    Some shops won’t do it, they say the rim is too narrow which is BS
  4. Oct 21, 2020 at 2:08 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Stick your hand over the top of your current tire and see/feel the clearance with that upper ball joint/control arm as its not much and now you know.
    Tire flex could eat a wider tire and if you run lower pressures you will have problems.
  5. Oct 21, 2020 at 4:49 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Those tires will work on your stock rims. They shouldn't rub front or back in the wheel well. It will be close on the UCA. I went with 255/85 r 16's and they are still tight up there (but no rub anywhere else...)
