stock 16" with 3" lift
Discussion in 'Wheels & Tires' started by tacoma44x44, Feb 22, 2009.
  1. Feb 22, 2009 at 8:06 PM
    tacoma44x44
    tacoma44x44 [OP] Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    can i run my stock 16" rims and tires with a 3" lift or do i need spacers eventually getting rims but cant afford it right away
  2. Feb 23, 2009 at 6:27 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if u can run them stock, u can run them w/ a 3" lift
  3. Feb 23, 2009 at 8:41 AM
    trailmaster308
    trailmaster308 Well-Known Member
    Louisiana
    PreRunner 3" Toytec Adj Coilovers 2" AAL
    I am currently running stock tires and rims with a 3 inch lift. looks goofy as hell but I haven't make my mind up what wheels/tires I want.
    Plus I have been buying lift in pieces so I can buy one major thing per pay check. UCA's will be in this week!!!!!
    Then my spinners on 20's will be in. j/k
  4. Feb 23, 2009 at 8:47 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    The necessity for spacers isn't related to the wheel size, but rather the tire size. If you stay with the 265/70 or 265/75 on the stock 16s, you'll be fine. If you go up to the 285/75s on the stock 16s, you'll need wheel spacers because you're gonna rub the UCAs. I'm running 285s on the stock 16s and I had to get spacers to clear 'em.
    Hope this helps...
  5. Feb 23, 2009 at 4:35 PM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    thanks guys for clearing that up also what does offset mean and what offsets are u guys running
  6. Feb 23, 2009 at 4:37 PM
    The_Hodge
    SC
    i think most are running a 4.5" backspacing. that will allow 285's w/o rubbing the UCA
  7. Feb 23, 2009 at 4:43 PM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    so offset is the same thing as backspacing?
  8. Feb 24, 2009 at 11:33 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    you could run most wheels with a 3" lift. i ran my 02 tacoma with stock wheels with a 3" for a while. and no problems.
    but now i replaced the stock steelies with 16x8 Pro comp
