stock 4X4 system not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WAF1997, Jan 13, 2012.
  1. Jan 13, 2012 at 7:30 PM
    WAF1997
    WAF1997 [OP] Member
    IOWA
    1997 TACOMA
    2 1/2 '' suspension lift, Flowmaster Exhaust custom bumper, rocker panel guards
    My 1997 Tacoma has stock automatic 4X4 hubs and when I shift into 4HI or 4LOW the drive shaft spins but no action from the wheels and the little 4X4 indicator light does not come on the dash. I have new axles and there is NO metallic or grinding noises coming from the system I have not been abusing or going off road with the truck. Does anyone have an idea what could be the problem.
    Thanks
  2. Jan 13, 2012 at 7:32 PM
    danimal92sport
    danimal92sport Well-Known Member
    dcab, 4WD, TRD O/R
    If you have a '97, I'd post in the 1st gen Tacoma section and let some of the 1st gen ADD experts chime in.
  3. Jan 13, 2012 at 7:39 PM
    WAF1997
    WAF1997 [OP] Member
    IOWA
    1997 TACOMA
    thanks
  4. Jan 13, 2012 at 7:40 PM
    T-Rex266
    T-Rex266 T-Rex Moderator
    ADD front diff accuator is my bet
  5. Jan 13, 2012 at 9:00 PM
    WAF1997
    WAF1997 [OP] Member
    IOWA
    1997 TACOMA
    I see that ADD actuator in the manual I will look into it thanks.
  6. Jan 25, 2012 at 4:56 PM
    WAF1997
    WAF1997 [OP] Member
    IOWA
    1997 TACOMA
    You were right sean266 it was the ADD actuator, I took it off tested the OHM’S, test was unsatisfactory. I got a new one for about 85$ and I’m good to go. Thanks for the help.
  7. Jan 25, 2012 at 5:57 PM
    T-Rex266
    No problemo buddy.
  8. Jun 23, 2013 at 8:06 PM
    Bulldog1969
    Bulldog1969 New Member
    Bulldog
    Texas
    Tacoma SR5 4x4
    Trailgear front bumper
    Where did you get one for $85?
