Stock 4x4 Tacoma non-TRD. Which locker option may be best
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaGuy, Jun 24, 2019.
  1. Jun 24, 2019 at 12:46 AM
    YotaGuy
    YotaGuy [OP] Well-Known Member
    Cody
    Phoenix, AZ
    08 DCSB 4x4 O/R & Yota crawler
    Stuff n junk
    1996 Tacoma 4x4 Standard, Non-TRD.
    Rear locker: is it worth it to get an ARB or Find an axle with elocker and wire in?
    Pros and cons, and which years would work without having to modify leaf perches for a trd elocker? 96-04 Tacoma trd OR?
    Thanks for helping
  2. Jun 24, 2019 at 4:08 AM
    tony2018
    tony2018 Well-Known Member
    well....this game has been played many times so....
  3. Jun 24, 2019 at 4:11 AM
    YotaGuy
    Cody
    Phoenix, AZ
    Stuff n junk
    Never gets boring am I right?:boink:
  4. Jun 24, 2019 at 5:12 AM
    tony2018
    sure, if you want someone else to build your ride for you.
  5. Jun 24, 2019 at 5:18 AM
    YotaGuy
    Cody
    Phoenix, AZ
    Stuff n junk
    Woah woah there man, I got some good ideas on the subject. Although, I’m still curious on others experiences and opinions about the setups for 1st gen Tacos.
  6. Jun 24, 2019 at 5:32 AM
    tony2018
    everybody builds theirs different depending on their needs although we also have the usual mall crawlers (not hating on you guys).
    Wulf likes this.
  7. Jun 24, 2019 at 5:37 AM
    YotaGuy
    Cody
    Phoenix, AZ
    Stuff n junk
    Lol well thank you for not hating. I changed my question for a more direct response. Maybe you could give some advice on that situation. Wondering if going through all the hassle of modifying the current housing for an ARB would be better to go the factory way.
  8. Jun 24, 2019 at 5:38 AM
    tony2018
    I think it would be wise, 1st gen parts oem parts are getting hard to find.
  9. Jun 24, 2019 at 4:56 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  10. Jun 24, 2019 at 5:08 PM
    707Tacoma
    707Tacoma Active Member
    Matthew
    2004 Toyota Tacoma
    Look around for a drum to drum e-locker axle. I snagged one with wiring for $700. With a little bit of research its a simple swap.
  11. Jun 24, 2019 at 6:00 PM
    Wulf
    rock raisin
    There are pros and cons to all. If you want to save money and can tolerate some quirky behavior an automatic locker like an Aussie or a Detroit can save you a lot of money over a selectable.
    If you think you'll want onboard air eventually the better ARB compressors can be used to fill tires and actuate the locker. ARBs can have issues with air leaks but that's usually due to a bad install and I've heard great things about ARBs customer service.
    In the Denver area a factory elocker axle is $1000+ so it's not necessarily the end all be all. I don't care much about tire wear so the rear of my truck is welded solid and I don't have any complaints and don't miss the quirky behavior of the Detroit lockers I've had in other vehicles.
