Stock 97 2.7l Reg Cab Gear Ratio?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Roberts23, Sep 12, 2011.
  1. Sep 12, 2011 at 6:25 AM
    Roberts23
    Roberts23 [OP] Active Member
    Cole
    Ga
    97 Tacoma 2.7l 4x4.
    Lower gears, Pro Comp Suspension, 33-12.50 Tires, All new audio system (Pioneer), intake system soon.
    I am 16, have had my lifted Tacoma for about 1 month now, and when i first put it in 4x4, in the dirt it did fine, but I should be able to drive on the highway in 4x4 too, but if I do, my truck hops around all over the road, it has lower gears in the rearend and stock in the front, i know thats why, so what is the gear ratio for the front so i can match that for my rearend?
  2. Sep 12, 2011 at 7:55 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV. I don't know your's, mine is 4.10
  3. Sep 12, 2011 at 8:07 AM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Bilstein 5100, 31x10.5 Michelin LTX AT2
    I think that my 95 Tacoma 2.7 has 3.51 by reading the code on the sticker on the door. Check your sticker, It will probably tell you what the factory gear ratio was.
  4. Sep 12, 2011 at 12:42 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    Hey welcome to TW! i dont think it is a good idea to drive in 4 wheel drive on the highway in the first place
  5. Sep 12, 2011 at 12:46 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Dude, you're going to grenade a diff or the transfer case. You have to run the same ratio in both diffs in 4x4, that's why it's hopping. You're trying to make one axle go faster than the other. Only run 4x4 in a straight line on pavement.
  6. Sep 12, 2011 at 12:52 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    this^^
    do NOT turn while in 4wd on the pavement. DO NOT.
    im just going to restate what 98tacoma27 has said.
    if you have different gear ratio in the front and in the rear, either the front or rear will spin faster than the other. EX...
    4.10s in the front and 4.88s in the rear, the front will spin faster than the rear, causing the rear to not keep up and the gears will end up grinding and BOOM. i know thats confusing. but yeah.
  7. Sep 12, 2011 at 12:53 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Welcome!
  8. Sep 14, 2011 at 5:25 AM
    Roberts23
    Cole
    Ga
    97 Tacoma 2.7l 4x4.
    Ya bro I know that i just need to get it fixed so i need to know the stock ratio.:)
  9. Sep 14, 2011 at 5:26 AM
    Roberts23
    Cole
    Ga
    97 Tacoma 2.7l 4x4.
    Why? Thats the point of having 4x4 in the winter for the snow:)
  10. Sep 14, 2011 at 5:29 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  11. Sep 14, 2011 at 5:31 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  12. Sep 17, 2011 at 10:15 AM
    Roberts23
    Cole
    Ga
    97 Tacoma 2.7l 4x4.
    I do not drive it in 4x4
  13. Sep 17, 2011 at 10:41 AM
    Roberts23
    Cole
    Ga
    97 Tacoma 2.7l 4x4.
    I found the axle code A/TM B03A, can you guys help me figure what ratio that is?
  14. Sep 17, 2011 at 10:49 AM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Yeah I thought it was considered normal to use 4WD in the winter during normal driving. That is why I turn my hubs in when the weather turns. It is similar to AC. People don't use it because it makes the engine work harder and thus use more fuel. But in Germany, and in my old Mercedes, the AC is to be used during warm and cold weather for climate control, because it is like a mega dehumidifier.
    I will continue to use my 4WD. If it blows up, I will sell the SOB.
  15. Sep 17, 2011 at 10:51 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I doubt the gears are different.
    If your gears were significantly different even on dirt things wouldn't be good. I can't imagine someone stupid enough to decide to change only the rear gears?
    When you get snow in georgia then use 4x4 on pavement, never on dry pavement.
  16. Sep 17, 2011 at 11:04 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    8"
    4.10
    2 pinion open diff
  17. Sep 17, 2011 at 11:05 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Your first post says otherwise ;)
  18. Sep 17, 2011 at 11:14 AM
    worthywads
    This thread wouldn't exist if he didn't. :confused:
  19. Sep 17, 2011 at 12:06 PM
    Roberts23
    Cole
    Ga
    97 Tacoma 2.7l 4x4.
    I appreciate it guys, and 98tacoma27, do u know that for sure?
  20. Sep 17, 2011 at 12:41 PM
    worthywads
    Do you know for sure your front is stock and rear is not?
    The chart say 4.10, that's for sure.
