Stock Air Box Mod?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oorah54, Jun 28, 2016.
  1. Jan 23, 2019 at 7:22 AM
    #541
    JabambyBrew
    JabambyBrew Well-Known Member
    JB
    Denver NC
    2019 Toyota Tacoma TRD PRO
    Have a couple of questions about this mod.
    1. Going to put the OVtune on my truck, should I wait until I get a KnN drop in filter and mod done before my tune?
    2. Any info about the average again in mpg or HP?
    G Tek Fab likes this.
  2. Jan 24, 2019 at 3:30 PM
    #542
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I had the G Tec Fab mod installed before adding the OVTune. The mpg went up some - may be 1 mpg. The stock air box mod does make the truck breath much easier at all operating ranges - well worth it in my opinion. Then I added 4.88 so the mpg went down about 3 mpg. Then I added OVTune and mileage went back up about 1 mpg. No need to get an expensive K&N filter. Stick with a dry OEM filter or equal. DO NOT add a K&N oiled filter - it will clog your MAF sensor and cause codes and other issues. As for HP - depends on which OVTune octane tune you run. I ran the 91, which is suppose to add HP. But HP gains are at high RPM. Not something you see across and rpm ranges. So don't buy the OVTune for HP - it does wonders for overall performance and is worth every penny. For my truck the 1.05 87 Octane performs perfect - makes stock, even with TSB's, seem like shit.
  3. Jan 24, 2019 at 5:23 PM
    #543
    JabambyBrew
    JB
    Denver NC
    Had a KnN filter on my 2000 Tacoma and never had a problem. Not looking for hp gain just better mpg and drivability. Plan on doing the 93 tune first. Them test the 86 tune with 93 octane. We will see what happens. Waiting on the 04B31 to be sent to me, I have a 2019 TRD pro.
    G Tek Fab and GoldenBrew[QUOTED] like this.
  4. Jan 25, 2019 at 10:24 AM
    #544
    Dylla34
    Dylla34 Well-Known Member
    Lemont
    03 TRD Prerunner
    Billy 5100's, Deckplate Mod, Magnaflow exhaust, Throtle body spacer.. , black rims, bull bar with lights and deer whistlers, black spray painted rims, Alpine head unit, Infintiy and alpines all around, and a 10 inch sound ordinance powered sub under passenger seat.
    I have the G Tec stock air box mod with a k/n air filter and it works fine.
    G Tek Fab and dc4e like this.
  5. Jan 21, 2020 at 12:37 PM
    #545
    jcentsi
    jcentsi Well-Known Member
    Julio
    19 Inferno Tacoma
    None
    I know it has ben a year since the last comment. Just looking to see if this is still a thing?
  6. Jan 21, 2020 at 2:04 PM
    #546
    JabambyBrew
    JB
    Denver NC
    I did it my truck and it work out great. Great instructions come with it. Took about an hour to install. Paired my with a KnN drop in filter, truck has better pull now. Work even better with the OVTune.
  7. Jan 21, 2020 at 2:06 PM
    #547
    jcentsi
    Julio
    19 Inferno Tacoma
    None
    Awesome. How do I get one?
  8. Jan 21, 2020 at 2:11 PM
    #548
    JabambyBrew
    JB
    Denver NC
  9. Jan 21, 2020 at 3:23 PM
    #549
    Big geek
    Big geek Well-Known Member
    D. Lengua, Scott4032, rlx02 and 2 others like this.
  10. Jan 21, 2020 at 5:12 PM
    #550
    jcentsi
    Julio
    19 Inferno Tacoma
    None
  11. Jan 21, 2020 at 7:25 PM
    #551
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
  12. Feb 19, 2020 at 7:42 PM
    #552
    Norsk
    Norsk Well-Known Member
    2024 Underground Gray Tacoma TRDOR Premium
    Link?!?!?!
  13. Feb 20, 2020 at 7:51 AM
    #553
    eurowner
    eurowner Duke Sky
    Scoty
    Post #548
  14. Nov 12, 2021 at 11:50 AM
    #554
    JohnBoss72
    JohnBoss72 New Member
    2020 White Tacoma SR5
    Pro Grille, black door overlays, black letter tailgate inserts, TRD intake accelerator, Toyota bed mat, Gator floor mats, Cup holder & door inserts
    Could you just use pvc pipe and rubber coupling?
  15. Nov 12, 2021 at 12:34 PM
    #555
    JohnBoss72
  16. Nov 12, 2021 at 1:02 PM
    #556
    Sungod
    Sungod Well-Known Member
    St Augustine
    I'm sure you could, but keep in mind that your engine is not starved for air and the intake diameter is not a restriction. If you want to throw money at things, you could probably find that putting TRD sticker on your bumper will give you the same HP gain and look a whole lot cooler.
    PoolFixer and JohnBoss72[QUOTED] like this.
  17. Nov 12, 2021 at 1:32 PM
    #557
    JohnBoss72
    agreed
  18. Nov 12, 2021 at 2:44 PM
    #558
    Sucksqueezebangblow
    Sucksqueezebangblow Well-Known Member
    Drake
    2017 TRD Off-road in Quicksand
    Stock as hell
    So is this going to suck up water and/or more dirt?
    Any real world gains to MPG?
  19. Nov 15, 2021 at 12:18 PM
    #559
    Sungod
    St Augustine
    No. It is just a bigger hole in the same spot. I guess it could let in more water and dirt since it could flow in one side and out the other. Imagine if you had a river that was flowing and you took a section that made it wider. Some people seem to have missed science class and think that you will get more water.
  20. Mar 22, 2024 at 3:18 PM
    #560
    Metalskool
    Metalskool Adversity Builds Character
    Michael
    2020 TRD 4WD
    I just ordered a Mishimoto silicone induction hose and am thinking I may do this mod. I have not decided if I want the kit (think $85 is a little high for a few fittings) or do my own ghetto mod with pvc fittings. I already have the KDMax tune. Pics to follow...
    wahoobie likes this.
