Stock and shock
Discussion in 'Suspension' started by Mandilou96, Jul 8, 2017.
  1. Jul 8, 2017 at 11:50 AM
    Mandilou96
    Mandilou96 [OP] New Member
    Amanda
    93271
    2007 Tacoma 4.0L V6 Base 4x4
    After market; headlight assembly, fog light assembly, brake light assembly, 17" rhino wheels, K&N air filter on both intake manifold and cabin.
    My truck is stock height and I wanna put a small lift on the front because my tires rub on the fenders. I also need new shocks in the front, can anyone give me guidance on what I need and a cost affective way to go about it?
  2. Jul 8, 2017 at 11:53 AM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    Welcome! What size tires re you running?
  3. Jul 8, 2017 at 11:54 AM
    Clearwater Bill
    Billy
    Largo Florida
    Lift might not fix it, depending on where the rub is, the wheel specs and the tire specs.
    5100's are the fav around here. Probably middle perch for your case.
    tcjacado likes this.
  4. Jul 8, 2017 at 11:55 AM
    tcjacado
    tcjacado Well-Known Member
    Welcome TW! Go with the bilstien 5100 adjustable and a aal in the rear.ypu will get 1.5 to 2 inches of lift.
    Edit also get that alignment checked. The wheel can be adjusted/moved more toward the front. The lift will not gaurantee your tires will not rub. You may end up having to do the cab mount chop it.
