Stock battery life expectancy in AZ?
Discussion in 'Arizona' started by HandOfGod, Jul 20, 2015.
  1. Jul 20, 2015 at 10:46 PM
    HandOfGod
    HandOfGod [OP] Well-Known Member
    Tacoma TRD 4x4
    Stock
    My 2014 Tacoma TRD Off-road just had its battery replaced today. Running pretty much stock with 19k on the odometer and about one year and a half, and was replaced under warranty. Dealership said I get another 2 year replacement for the stock Toyota battery. Question is, should I just get an upgraded battery or stick with OEM? I have had Optima red tops in my previous vehicles but know that they kinda suck now. What are you all running in your vehicles in Arizona? Die hard, Interstate, Duralast etc...
  2. Jul 20, 2015 at 10:48 PM
    thebeeler
    thebeeler part of the problem
    Daniel
    Yuma
    Your sister
    Total Chaos, Plate bumpers, e-locker, etc
    I only run Optimas. They used to last 5-6 years. They last 3-4years now. A good wet cell will last around 3years in AZ also. But I don't like to deal with corrosion on my battery cables. Your OEM battery should last around 3 years.
  3. Jul 20, 2015 at 11:17 PM
    Martimus
    Martimus Well-Known Member
    Martin
    'neath a cactus
    2012 PreRunner SR5
    My experience with wet cell batteries in AZ is a wee bit different. I've found that most of the wet cell batteries have typically died in about 2 years max.
    This climate is just plain tough on car batteries...
  4. Jul 20, 2015 at 11:48 PM
    AnchorCop
    AnchorCop Well-Known Member
    Arizona
    13 TRD DCSB 4x4
    OEM stock cause it's free, until you have to go into your own pocket. On my 13 I got about 20k. Got better things to spend my money on. 2 cents.
  5. Jul 21, 2015 at 7:24 AM
    HandOfGod
    Tacoma TRD 4x4
    Stock
    I will use the OEM battery until the warranty runs out. Just wanted to know what the alternatives are for when I have to buy a new battery on my own dime.
  6. Jul 21, 2015 at 7:31 AM
    jim2009taco
    jim2009taco Active Member
    jim
    Phoenix, AZ
    2009 4X4 TRD Sport SR5
    3" front spacer lift (for now) , add a leaf rear, SPC UCA's,265/70/17 Nitto G2 ,DC Gun Metal 7'S
    Costco! No hassle warranty, Interstate batteries. Cheapest in town and as good as any other
  7. Jul 21, 2015 at 8:17 AM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    About 75% of the battery's OEM and after market are made by Johnson Controls in Mexico They make automotive, aircraft and industrial battery's and sell under many brand names including Optima The other major players are Exide and Interstate for automotive use. Most OEM battery's are conventional flooded cell [wet] battery's and for a daily driver work great and I expect 3 to 4 years of normal service. Over charge and corroded terminals are there worst enemy's +heat is a killer. An AGM battery is a great option for any application where severe shock and vibration [off road ] are a problem they are stronger spill proof and as general rule have more capacity in a given size than a flooded cell but are more apt to be destroy by overcharge and heat. In my experience Interstate and Johnson make great products, Exide makes a good Battery but they tend to leak and corrode more than the others. Bottom line Buy the best you can afford and any of them should last you through 3 or4 AZ summers.
  8. Jul 30, 2015 at 4:32 PM
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    Yeah my Stock 2012 battery leaked acid everywhere and the dealer wouldn't do anything till it died. I went to Sear Platinum (before it died) to replace it. Keep the stock and do a dual battery setup while the stock is still good, then you are totally covered.
