Stock Battery vs New Winch
Discussion in 'Recovery' started by SeniorSpan, Apr 23, 2020.
  1. Apr 23, 2020 at 7:36 AM
    SeniorSpan
    SeniorSpan [OP] Well-Known Member
    Bob
    Colorado Springs
    23 TRD DCSB OR
    G'day all,
    In general, is it recommended to replace the Tacoma stock battery when installing a winch with more than 8,000 pounds capacity?
    Thanks for your time.
  2. Apr 25, 2020 at 4:35 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Lots of variables here. The 2nd gen came with a larger battery if you got the tow package and lots of people run with just that.
    What size of battery is in your truck now?
    Do you plan to use it a lot or is it there just in case you get stuck?
    From the recommendations I've read an 8k winch is the minimum for our trucks, lots run 9k -9.5k and 12k is overkill.
  3. Apr 25, 2020 at 5:32 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Most winches I believe require 650CCA and I may be wrong but I think stock Tacoma batteries are at least that.
  4. Apr 26, 2020 at 5:22 PM
    SeniorSpan
    Bob
    Colorado Springs
    23 TRD DCSB OR
    Thanks for the reply.
    I should've provided truck details to expect a reasonable answer.
    2018 TRD OR with OEM tow package; to my surprise the OEM battery is only 582 cold cranking amps. Had I checked the battery before asking the question I coulda had a good clue to the answer.
    As for usage, been looking at a 10k Smithybuilt x20 as a safety device. I'm out alone 50% of the time and a hard core believer in if ya get your self in trouble ya should be prepared to get your self out of trouble. That doesn't always work, but at least I know I did all I could.
    Cheers
