stock brakes 100,000 + mi. I am Third Gens ONLY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shotgunbilly420, Mar 26, 2021.
  1. Mar 26, 2021 at 12:27 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Yeah really no reason you can't get 120+ out of the rear drums
    shakerhood and confirm45[QUOTED] like this.
  2. Mar 26, 2021 at 12:37 PM
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    I had the opposite experience with my stealership. Had the front rotors and pads replaced at 16k miles due to warped rotors. The service center manager gave me a lecture on propped braking. :jerkoff: Then charged me $250 to replace. :luvya: I found a new dealer. No issues since and now approaching 30k miles.
  3. Mar 26, 2021 at 12:44 PM
    Tacowin1013
    Definitely frustrating when it seems its 100% up to their discretion if they address it
    shakerhood and 79CHKCHK[QUOTED] like this.
  4. Mar 26, 2021 at 12:48 PM
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    42k mileage and they said I'm half way through my brakes.
  5. Mar 26, 2021 at 1:17 PM
    Summitroad
    Summitroad Well-Known Member
    Northen CA
    TRD OR 4X4
    I did put a lot of miles traveling between OR and CA, what surprised me the most was the clutch, because I occasionally tow light loads with a single axle trailer.
  6. Mar 26, 2021 at 1:27 PM
    skifishbum
    skifishbum Well-Known Member
    Reno, NV
    17 DCSB -> 22 DCLB
    My old commute involved a ton of elevation. house is at 4500 ft, pass tops out around 8300 ft then back down to Tahoe which is about 6000 ft. I’m shocked mine lasted that long. I also have a go fast camper on mine with 33s.
    Most Highway driving won’t cause much issue. Big difference between taking 80 and 395 in the sierras vs Mt.rose highway daily.
    shotgunbilly420[OP] likes this.
  7. Mar 26, 2021 at 1:31 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Def makes sense, and good point
    Shocked likes this.
  8. Mar 26, 2021 at 1:33 PM
    GumShoe
    GumShoe Well-Known Member
    New Mexico
    MGM 2016 Tacoma SR V6 4x4 DCSB
    Changed my brake pads at 75k miles. Still had some life to them but better to be safe than sorry.
  9. Mar 26, 2021 at 1:40 PM
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    My 2017 is at 80k now and still on original. I give credit to it being a manual and I downshift a lot on upcoming red lights and hills..
  10. Mar 26, 2021 at 1:58 PM
    shotgunbilly420
    shotgunbilly420 [OP] OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    See when I'm on steep grades I use my gear selector and combo of brakes . Downshift slows the motor from transmission but light braking help slow down and take strain from the transmission doing all the work
  11. Mar 26, 2021 at 2:02 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Being light on the brakes and not getting temps up into the ideal operating range can actually be worse for wear and performance.
    The front pad area/vehicle weight ratio is pretty good on this truck and the rotor/caliper are not undersized like they are on some trucks. With a healthy transfer layer and not overheating the brakes, friction material is consumed very slowly and pad parent material to rotor parent material contact is rare.
  12. Mar 26, 2021 at 2:11 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I'm at 80k on my 3rd gen. Every time I go in for service I expect the pads to be ready for replacement, and as we know dealers are all about proposing some maintenance items early, but even when I ask they still indicate I'm good "for the foreseeable future" on both fronts and rears. I'm not terribly easy on brakes generally speaking, though the transmission braking is very prevalent on these trucks and likely has helped reduce wear a ton as a result when going down hills and such.
  13. Mar 26, 2021 at 2:27 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I also use the automatic shifter often to help slow down. I tow a lot, and it helps for sure!
  14. Mar 26, 2021 at 2:31 PM
    holvey
    holvey Well-Known Member
    Brian
    Portland, OR
    2020 DCSB TRD OR
    Not Taco related, but my previous car a Mazda 3 made it 110,000 miles on the original brakes up front, and I traded it in with the rears still in good shape in 90% city driving/winding and hilly roads around here in Portland. I drove that thing like a track car, with rarely a set of tires lasting beyond 30,000 miles even with regular tire rotation. The thing would eat tires, but brakes were fine every time. I would say that I am pretty light on the brake pedal though. I would always downshift with a manual, and not follow too close.
    I've only put 7000 miles on my OR, but I've had the opposite perception in my truck. I find the engine/transmission braking to barely slow my truck down even when I put it in a lower gear. Some of the regular roads I drive may have a downward slope when I am thinking they are flat, but a lot of times I can lift my foot and it feels like it's rolling in neutral.
  15. Mar 26, 2021 at 2:31 PM
    #35
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    Rust takes it's toll here. Rust gets a bite on the rotors and that eats the pads. Or the pads rust where they contact the calipers and don't slide freely.
    And then there's the pad retaining pins that rust solidly into the calipers unless they are taken out, cleaned and lubed on a regular basis.
  16. Mar 26, 2021 at 2:39 PM
    #36
    Shocked
    Shocked Well-Known Member
    2021 Tacoma TRD Pro
    I swear I have a stop sign ever 500 feet were I live.
  17. Mar 26, 2021 at 2:43 PM
    #37
    ryanvar42
    None
    Good and thank you
  18. Mar 26, 2021 at 8:12 PM
    #38
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    I just replaced my original front pads and rotors at 221,000 miles on a 2008 4x4 MT. Just as amazing is all 4 pads were worn down to a uniform 1/16". I inspected the rear shoes and I think they might make it to 400,000 miles if nothing fails.
