Stock Brakes able to stop 4-Lo???
Discussion in '1st Gen. Tacomas (1995-2004)' started by bawilson21, Jul 20, 2015.
  1. Jul 20, 2015 at 1:14 PM
    bawilson21
    bawilson21 [OP] Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    Just a quick question for those with 4WD...When you guys are in 4-Lo and and are in 1st gear, are the stock brakes able to hold your truck from moving? Primarily interested in hearing from those with a manual transmission.
  2. Jul 20, 2015 at 1:16 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    It would be a pretty poor design if they didn't...
    Do the answer is yes(assuming) everything is in proper working order.
  3. Jul 20, 2015 at 2:50 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Why it makes no sense??
    If my foot is on the brake the right is on the clutch
    If your line lock using just your front brakes can hold 600 + horsepower to do a burn out I am sure 4 brakes can but it will just stall.
  4. Jul 20, 2015 at 5:15 PM
    bawilson21
    Bryan
    WA
    Well it sounds like i need to take a look at my brakes. 4Lo overpowers my brakes and the engine wont stall with the brakes fully depressed and foot off the clutch.
  5. Jul 20, 2015 at 7:29 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    How do you even stop then while in normal driving conditions?
  6. Jul 20, 2015 at 7:35 PM
    OyamaTacoma
    OyamaTacoma Active Member
    Thomas
    Oyama British Columbia
    07 Silver FJ Cruiser 6MT
    Airaid cold air intake Custom sub box Aftermarket stereo Yakima bike rack Blind spot mirrors
    How soft is your brake pedal? Should be firm. Might have air in your brake lines somewhere. If you aren't a mechanic bring it to one
  7. Jul 20, 2015 at 8:28 PM
    bawilson21
    Bryan
    WA
    Brakes seem fine normally.. They arent super soft, nor super hard. I do almost all my own work on my cars. Timing belts on a Camry and Civic, and I've replaced the clutch on my Tacoma. Though it has been awhile since I've replaced the brakes, but like I said, the brakes seem fine while driving under normal conditions. I've towed a travel trailer (approx 3000#) with no issues. Its just whenever I have 4lo engaged with the truck in gear, it doesnt stall....I have new shoes and pads I got awhile ago for the truck that I'll put on once I find me some brembo blanks. When I get to it, I'll report back here and let you all know if 4lo still overpowers the brakes.
    Still interested in hearing from 1st gen owners if their manual trans. truck stalls in 4lo when brakes are applied.
  8. Jul 20, 2015 at 8:35 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    I have manual trans and 4wd and can safely say that if the wheels are turning I'm not stalling.. and that is pretty much across the board, not just in 4lo but I'd say that in 4lo I can eek it that much closer to stopped without stalling. My tires are oversized and my brakes are borderline dangerous when it comes to driving in traffic at speeds over 45mph especially in wet conditions. In 4lo, however, the truck is moving WAAAY too slowly to do anything but eventually stop with the brakes applied no matter what gear or speed I'm Low-gearin' it in! Hope this answer is of some use to you;)
  9. Jul 20, 2015 at 8:41 PM
    bawilson21
    Bryan
    WA
    So you can't stop your truck in 4lo while its in gear?
  10. Jul 20, 2015 at 8:41 PM
    bry838
    oregon
    I can stop on command in 4 low in my truck. 5speed
  11. Jul 20, 2015 at 8:44 PM
    WheelInTheSky
    G
    Jackson Hole
    Perhaps I made that a bit confusing.
    In 4Lo I only stall if the wheels stop turning.
    Braking in 4Lo is the easiest braking I ever experience and braking hard WILL absolutely bring me to a complete stop. Without pushing in the clutch, this has, and will, result in stalling.
  12. Jul 20, 2015 at 11:19 PM
    bawilson21
    Bryan
    WA
    Gotcha... Ok. This makes sense.. something must not be right. I imagine the rear shoes arent grabbing aswell as they should, but youd think just the front pads alone would be able to stop it at a crawl. Eitherway, it will all be replaced. Thanks @WheelInTheSky
  13. Jul 21, 2015 at 1:28 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Not being smart here but is your clutch slipping?
    Is your idle really high?
    Now I really would not like to try but I think if the rpm was high enough you could over come the brake pressure but my luck something expensive would break.
    First Gear low range I step on just the brake pedal the truck stops and stalls.
  14. Jul 21, 2015 at 1:48 AM
    bawilson21
    Bryan
    WA
    Thanks for the feedback @Wyoming09 I replaced the clutch less then 10K miles ago so its not that. Im all to familiar with the symptoms of a slipping clutch. No high idle in my case. It actually drops as it should below the 700rpm mark when in gear with 4 low and brakes fully applied... Just weak brakes I guess. Its odd because I dont notice anything while Im driving normally, even when towing. But thats why I like to keep parts on hand so I can easily replace them....when I get to it.. lol. (My Tacoma is not my daily driver)
  15. Jul 21, 2015 at 2:12 PM
    98 Taco Max
    98 Taco Max Well-Known Member
    Max
    Calgary, AB
    v6 Tacoma 4x4
    yes the brakes should be able to stop your truck in any gear, low or high. unless you're stomping on the gas in gear at the same time as applying the brakes then it depends...
    if you're in 4 lo and 1st gear, no foot on the gas and you hit the brakes you should stop and shouldn't be able to move anywhere and your engine should stall. if your engine doesn't stall and your tires aren't spinning even though you're still in gear i would think the the clutch is slipping or something like that
    if your engine doesn't stall and your tires are still spinning even though you've got the brakes applied then somethings upwith your brakes
  16. Jul 21, 2015 at 2:34 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    OP really just has a automatic and doesn't know it.
  17. Jul 21, 2015 at 2:38 PM
    WheelInTheSky
    G
    Jackson Hole
    HAHAHA oh man im sorry that made me smile:rofl:
  18. Jul 21, 2015 at 2:39 PM
    bry838
    oregon
    ^^^lol^^^
    Yeah the only thing I can think of and I know you said u replaced it, the clutch... Since you can stop just fine any other time I find it hard to believe its a brake issue. Maybe clutch pedal outta adjustment allowing a little slip in 4 low conditions....??
