Stock/Butt Extender
Discussion in 'Guns & Hunting' started by kbx10, Dec 18, 2009.
  1. Dec 18, 2009 at 8:40 PM
    kbx10
    kbx10 [OP] Well-Known Member
    Kyle
    Chicago
    The beginning of something big...
    Tint, Autopage Security
    I am looking at buying a Remington 1100 from my uncle but the stock is about an inch or two too short. It is a beautiful gun and has great wood work on the stock. I was wondering if anyone knows of an extension I can get for the end of it? Preferably something that screws in and not a sleeve, but anything would be nice.
    Thanks,
    KBX
  2. Dec 18, 2009 at 8:43 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
  3. Dec 18, 2009 at 8:55 PM
    kbx10
    Kyle
    Chicago
    Thanks...tried that already and didn't find what I was looking for.
    Clever though...
  4. Dec 18, 2009 at 9:08 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    There are countless aftermarket stocks available for an 1100. Most of which are quite reasonably priced. Is there some reason why you're particularly attached to the original stock?
  5. Dec 18, 2009 at 9:21 PM
    kbx10
    Kyle
    Chicago
    The gun is my uncles and it has great original wood work on it that looks awesome. I would like to keep it original if possible and not change it out.
  6. Dec 18, 2009 at 9:28 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    That's fine. Then you're stuck either putting a thicker recoil pad on and/or putting spacers between the pad and stock. Spacers and pads can be found in nearly all thicknesses and they can even be stacked. They probably make them precut for an 1100 but every stock is a little different so they rarely fit quite perfect. I would recommend getting the sand to fit type and have a smith put it on (he can order it himself) or if you're handy, you can DIY.
  7. Dec 18, 2009 at 9:47 PM
    kbx10
    Kyle
    Chicago
    Thanks a lot. Now that I look for that, there are a lot more options. Anything you would recommend?
  8. Dec 18, 2009 at 10:04 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    I've never really heard anything bad about any of the products available. I think it's going to come down to preference more than anything. Earlier you mentioned it's an inch or two too short. Be aware, an inch or two is A LOT when it comes to length of pull (LOP). Typically, when it comes to LOP, people talk about 1/4" adjustments. Do some research online on how to measure LOP, what average shotgun LOP is, check your shotgun, be aware of your height/arm length, and make some choices from there. Make sure you know what you want. No spacers or pads are permanent, but that doesn't mean you want to F it up the first time because you didn't know any better then turn around and have to redo it.
