Stock DCLB Taco sagging. carrying camping gear.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BalutTaco, Jun 15, 2019.
  1. Jun 15, 2019 at 6:58 AM
    BalutTaco
    BalutTaco [OP] Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    So last week I went out for a week long camping trip. I loaded up my truck with firewood and camping gear. My truck was sagging bad. How do i prevent that from happening? I know later in the future I'm planning to buy a RTT.
  2. Jun 15, 2019 at 7:00 AM
    Itchyfeet
    Itchyfeet Well-Known Member
  3. Jun 15, 2019 at 7:00 AM
    RedTacoATX
    RedTacoATX Well-Known Member
    Bryan
    Austin, TX
    Black 2016 Tacoma TRD skeeewp DCSB & 1992 DLX RC V6 4X4 MT 35's FTW
    None....yet.
    Definitely carry less wood. That stuff is heavy!
  4. Jun 15, 2019 at 7:01 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    OME HD dakar leaf pack
    eurowner likes this.
  5. Jun 15, 2019 at 7:01 AM
    BalutTaco
    Eucalyptus wood LOL. Didn't want to spend $8 for a bundle of wood. Was out camping for a whole week.
  6. Jun 15, 2019 at 7:03 AM
    BassAckwards
    If you want to stay stock height but need more support, firestone ride rite airbags will serve you well
    hoch and eurowner like this.
  7. Jun 15, 2019 at 7:05 AM
    BalutTaco
    I Want to lift it but I don't want to void my warranty. barely put 5k miles on it :(
    BassAckwards[QUOTED] likes this.
  8. Jun 15, 2019 at 7:05 AM
    Shellshock
    Iowa
    One of the following
    Sumosprings
    Airbags
    Leaf pack (Icon RXT, Dakar, alcan)
  9. Jun 15, 2019 at 7:05 AM
    Shellshock
    Iowa
    Warranty is overrated
  10. Jun 15, 2019 at 7:12 AM
    BassAckwards
    I would go with airbags until your warranty is up. I have been running some firestones on mine for a couple years now, they work good
    cblow5 likes this.
  11. Jun 15, 2019 at 7:13 AM
    BalutTaco
    How much do airbags cost? I was looking at the leaf pack. Dakar Old man emu
  12. Jun 15, 2019 at 7:19 AM
    BassAckwards
    I think mine were around 300 when i bought them..
    Having run airbags, i will say that i am switching to dakars in the future, because they get a little bouncy when you load them down. But, for your application they could work well. Basically youll only put more than 5spi in them when you have a load, and when you dont, you can just lower the pressure and it wont cause you problems with ride quality
  13. Jun 15, 2019 at 7:24 AM
    MuddySquirrel
    MuddySquirrel Well-Known Member
    Will
    Phoenix
    2015 Taco 6-speed Off-Road
    Another vote for Sumosprings - they’re sturdy, simple to install, add 1000lbs to 1500lbs of weight capacity, are relatively cheap (~$200), maintenance free, and don’t limit your downtravel.
    The other nice thing is that they impact your day-to-day drive much less than a new leaf pack: your stock spring rate is unaffected until the springs compress enough to hit the Sumos. When carrying a full bed/RTT a HD spring pack will ride nicely (and is the right choice for a permanently mounted tent) but it will ride stiff when unloaded. Sumos work really well for occasional heavy loads.
    Satchmo and 71tattooguy like this.
  14. Jun 15, 2019 at 7:25 AM
    BalutTaco
    Ahhh. I've seen some dakars for $250? is that correct or I'm looking at something else? lol
  15. Jun 15, 2019 at 7:34 AM
    BalutTaco
    MMMMM. Dang so many options!!! Are you running sumoSprings? Do people end up upgrading to a leaf pack? I'm just trying to make one good purchases for the long run!!
  16. Jun 15, 2019 at 7:46 AM
    BassAckwards
    That was probably for one spring.. theyre around 550 for a new pair
    BalutTaco[QUOTED][OP] likes this.
  17. Jun 15, 2019 at 7:51 AM
    BalutTaco
    AHH shit lol. $550 plus labor? are they easy to install ?
  18. Jun 15, 2019 at 7:59 AM
    BassAckwards
    Install isnt too bad, im sure if you posted in your regional section here on Tacoma world, someone would be willing to help you for cheap if you arent comfortable doing it yourself
  19. Jun 15, 2019 at 8:54 AM
    MuddySquirrel
    Will
    Phoenix
    Yes. I got SumoSprings after frying my stock rear leaves. Before I’d slam into the bumpstops going over speedbumps and potholes - adding the sumos gave me back ~1/2” of ride height and rode firmly but the truck felt planted and no longer had jarring jolts every time I went over potholed or bumpy sections.
    I’ve since replaced my leaf packs with 3/4 ton Chevy 63s and kept the SumoSprings as bump stops. The 63 swap is somewhat involved and is not one of my first recommendations for springs, but that size does offer spring ratings up to 3k lbs per side if you get super heavy.
    I currently run ~500lbs over stock all the time (tent, rack, steel skids, winch, dual Group 31s, fuel, water, kitchen sink) and the springs ride smoothly: they ride even better with another 200 lbs.
    With less weight, the rear was stiff: still better than stock, but not its loaded butter smooth ride. The downside to springs is that you have to match your springs to your weight for the best ride and that can be hard with a changing vehicle weight: too much spring is stiff, too little is rolly and finds the bump stops.
    Airbags do excel with changing weights: I don’t have personal experience with them.
  20. Jul 19, 2019 at 8:38 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Everything i have read says that they do not increase your weight capacity, they just prevent sag. it doesn't suddenly turn the tacoma int a 1 ton pickup..
    From Sumo springs web site
    Will SuperSprings or other helper springs increase my GVWR?
    No. Nothing can increase your GVWR. It is set by the manufacturer of the vehicle. It should never be exceeded. There is no suspension product in the world that can increase GVWR.
    hoch likes this.
