stock e locker on an older taco?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RattleTractor, May 8, 2009.
  1. May 8, 2009 at 9:55 PM
    RattleTractor
    RattleTractor [OP] Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Hey so i was wondering if it was possible to fit an e locker from a 98-04 TRD taco onto my 96.
    It seems like it should work, but maybe not...
    any theories/experiences/advice for this? i figure it would be cheaper than an air locker.
  2. May 8, 2009 at 11:48 PM
    stikkimikki87
    stikkimikki87 Well-Known Member
    Pensacola FL
    d44, 37s, all 4 wheels turn!
    uhh...everything? lol
    the axle will swap in easily, but you cant put the locker in your current axle if thats what you meant
  3. May 9, 2009 at 6:00 AM
    RattleTractor
    Harry
    VT
    yea thats what i thought. someone i talked to thought you could just swap the assembly, but i thought you had to do the whole axle.
    the driveshaft will still fit into the either axle though?
  4. May 9, 2009 at 6:20 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    Oh yes you can, you just need to modify your housing to accept the e locker.
    I will look for a link.
    edt: as long as you have a 8 in housing.
    http://carterswebsite.com/4runner/mods/locker/
  5. May 9, 2009 at 7:51 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    No, this won't work for the OP's situation ...
    The link above is for retrofitting a factory e-locker (based on the 'V6 / Turbo' differential unit) into a 4Runner (which used either the 'V6 / Turbo' or, in some rare cases, the so-called '7.5' unit). Internal parts can be interchangeable between these two units.
    NO 1995.5 - 2004 Tacoma came with the 'V6 / Turbo' differential (except for those equipped with the e-locker based on it). Assuming it's a 4X4, the OP's 1996 Taco has the '8.4' differential. You cannot swap internals from a 'V6 / Turbo' into an '8.4' without massive reworking of the '8.4' carrier (housing). This is a much tougher 'surgery' than described in the 4Runner writeup cited above, and it has been demonstrated to cost a lot more than it's worth.
  6. May 9, 2009 at 8:32 AM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    right this only works for a 8 in housing if you have 8.4 you are SOL and would need to go ARB.
  7. May 9, 2009 at 10:16 AM
    RattleTractor
    Harry
    VT
    crap. thats what i feared. how can i check?
    i mean, its just a 96 4wd base model if anyone knows for sure, although enola gaia seem says its an 8.4.
    oh well. thanks guys.
  8. May 10, 2009 at 7:55 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
