Stock ECU Tuning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, May 15, 2018.
  1. May 17, 2018 at 7:23 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I too am curious about what this tune can do for an NA Tacoma.
  2. May 17, 2018 at 7:27 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I don't think this is a premade tune. The user needs to be able tune his own shizz.
  3. May 17, 2018 at 7:27 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Precisely.
  4. May 18, 2018 at 11:14 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    And turn off things you don't want/need, ie: speed limiter.
    Roostfactor and BassAckwards like this.
  5. May 18, 2018 at 11:23 AM
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Do you know what the speed is limited to?
  6. May 18, 2018 at 11:58 AM
    ThomasMore66
    Don't you?
  7. May 18, 2018 at 12:02 PM
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Sadly I do not know, fastest ive gone is about 110. But I usually have my bestop on and at that speed I was worried about it flying off.
  8. May 18, 2018 at 12:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    ~110-115, & ~120. It changes depending on a few model variables.
  9. May 18, 2018 at 12:15 PM
    ThomasMore66
    Get out there and put your foot down! I think mine is 115. Disappointing is what it is. And don't lecture me about speed ratings. I was WFO in mom's Buick way before anyone thought about speed rating tires.
  10. May 18, 2018 at 12:58 PM
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Maybe i did hit the limit for a second and I didnt realize it lol
  11. May 18, 2018 at 2:13 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I thought the limit was listed on those white signs. :notsure:
    outlawtacoma, Roostfactor and jojotoo like this.
  12. May 18, 2018 at 2:41 PM
    ThomasMore66
    Noooo. That’s a suggestion. A limit is a physical limitation to the truck going any faster. A governor is a false limit.
    techbill, Norton, Nedrolls and 2 others like this.
  13. May 18, 2018 at 2:52 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Saeros, cdelgado14, Boring and 6 others like this.
  14. May 24, 2018 at 8:14 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    @ThomasMore66 I have almost never heard of seen anyone use the "WFO" acronym outside of my motocross circle. Impressed!
  15. May 24, 2018 at 8:21 AM
    #35
    ThomasMore66
    When in doubt, gas it out?
  16. May 24, 2018 at 8:29 AM
    #36
    Roostfactor
    TX panhandle
    Meemmorrieeeees!
    Didnt you ever think there was a reason for my username?
    5thGearPinned likes this.
  17. May 24, 2018 at 8:32 AM
    #37
    ThomasMore66
  18. May 24, 2018 at 9:34 AM
    #38
    Roostfactor
    TX panhandle
  19. May 24, 2018 at 9:35 AM
    #39
    Roostfactor
    TX panhandle
    Good form. You or Chad Reed? Haha.
  20. May 24, 2018 at 3:09 PM
    #40
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Photoshop :D
