Stock ECU Tuning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, May 15, 2018.
  1. Jun 11, 2018 at 7:32 PM
    #101
    Old School
    Old School You are ignoring covfefe by this member.
    Looks like we're starting to see a problem here with the shift patterns. My truck has been doing this basically since the beginning, and that was stock tires, I'm only running 275s now.
    I've also talked with other owners who are experiencing the same problem with the shifting.
    Can someone start another thread about this shift issue?
    I don't currently have my laptop working. ..
    @OVTune
    I would be happy to bring my truck down to you to address this issue
    Biscuits likes this.
  2. Jun 12, 2018 at 7:51 AM
    #102
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    nope but seems as though you were the straw that broke the camels back for OVTune and any future beta testers.
    ThomasMore66 likes this.
  3. Jun 13, 2018 at 4:42 AM
    #103
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Thanks for sharing how you feel. I don't feel guilty for it and neither should you. :)
  4. Jun 13, 2018 at 4:56 AM
    #104
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    You have to understand this guy seems to enjoy being "that guy."
    Anyways some UI changes have been made and we implemented some tuning guide info, the software is now ready and we will be posting some videos and images soon.
  5. Jun 13, 2018 at 2:09 PM
    #105
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
  6. Jun 14, 2018 at 10:17 AM
    #106
    OVTune
    OVTune
    Complete redesign complete
    (image is bare-bone with all information / functions / calibration data on the panels removed) Axis names Removed, etc
    05Taco4x4, Biscuits, henryp and 3 others like this.
  7. Jun 14, 2018 at 11:48 AM
    #107
    Old School
    I can't wait!
    When do you expect to resume sales?
  8. Jun 17, 2018 at 2:26 AM
    #108
    OVTune
    OVTune
    Injector Scaling is now available
  9. Jun 17, 2018 at 4:03 AM
    #109
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    :spy:
  10. Jun 17, 2018 at 6:31 AM
    #110
    OVTune
    OVTune
    Software is complete
    Current list of available tune-able parameters
    -Sensors
    - Injector Scaling
    - Injector Latency for voltage
    - MAF Sensor Scaling
    - MAF Limits
    - Coolant Temperature Sensor Scaling
    - Intake Air Temperature Sensor Scaling
    Fueling-
    - Injection Maximum enrichment command
    - Injection Minimum enrichment command
    - Power enrichment
    - Fuel target Table
    - Closed Loop Target Tabe
    - Fuel Airflow Correction
    - Low / High RPM Lambda
    Ignition-
    -Idle Ignition Timing
    - Ignition Timing Base
    - Ignition Base (TRD)
    - Ignition Timing Target Correction
    - Ignition Timing Limit
    - Ignition Timing H/L
    - Ignition Timing Compensation based on IAT
    - Ignition Timing Correction for Valve Angles
    - Ignition Retard Transient Gear Change
    - Coil Dwell Time
    -Ignition Timing Lowest Retard
    Knock-
    -Knock Detection Sensitivity (cylinders)
    -Knock Detection RPM Limits
    Compensations-
    - Air Temperature to MAF Flow Correction
    - Cylinder Filling Calculation
    Throttle-
    - Throttle Angle Translation
    - Expected Throttle
    - Throttle To Torque
    - Torque to Throttle
    - Throttle Transient Enrichment
    - Throttle Transient to vehicle speed
    - Throttle Target mapping (various drive modes)
    - Driver Demand control
    Transmission-
    -Calculated Torque - drive
    -Transmission Torque for Shift
    - Upshift (all gears)
    - Downshift (all gears)
    -Transmission Shift Torque Expected
    Valve Timing-
    - Intake valve Timing Advance
    DTC-
    DTC Control
  11. Jun 17, 2018 at 6:57 AM
    #111
    OVTune
    OVTune
    absolutely. All the way up to 2018 4Runner
  12. Jun 17, 2018 at 7:11 AM
    #112
    TacoMeSir
    TacoMeSir WiFi Guru
    Tim
    North GA
    2024 TRD Off-Road Hybrid Premium
    Stock
  13. Jun 17, 2018 at 9:41 AM
    #113
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    loginfailed likes this.
  14. Jun 17, 2018 at 9:48 AM
    #114
    Old School
    @OVTune
    Mat, when are you planning on reopening sales?
    cdelgado14 and taco2010trd like this.
  15. Jun 17, 2018 at 1:03 PM
    #115
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Perhaps...
  16. Jun 17, 2018 at 5:44 PM
    #116
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    @OVTune where did u relocate to? I remember reading u were moving. Hoping closer to me. Would love to buy ur tune and have it dynoed and tuned by you
  17. Jun 17, 2018 at 9:17 PM
    #117
    OVTune
    OVTune
    Virginia, in July.
    Software is available but tools for flashing are not at the moment because I'm out of the country. (tools can be purchased by 3rd party I will explain how). There will be a few people who will get updated with this latest version and I think they are on the forums
  18. Jun 18, 2018 at 6:14 AM
    #118
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    ill just wait. not in any rush. thanks for the updates. and screw all the haters. if they dont like what you do tell them to do it them selfs
  19. Jun 23, 2018 at 4:55 AM
    #119
    OVTune
    OVTune
    All TRD SC calibrations 2010+ are supported. (older ECUs we are still finishing mapping out)
    Once we pick up our R&D 4.0 truck we will dyno tune one and video it with our software to show you what's possible
    05Taco4x4 and loginfailed like this.
  20. Jun 23, 2018 at 5:59 AM
    #120
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine has done that since I got it. Even after replacing the transmission with one from IPT.
    I’ve found that I don’t need to shift to 4th and back to 5th. I just accelerate a bit more in 4th and then ease off the accelerator slowly. It will shift to 5th on its own.
    I’m not saying it isn’t annoying, but I’ve adapted to it. I’d definitely like to tinker with the shift behavior, especially given all of the mods I’ve done. The stock shift logic is definitely set up for what my truck has going on under the hood.
    jojotoo and henryp[QUOTED] like this.
