Stock ECU Tuning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, May 15, 2018.
  1. Aug 9, 2018 at 11:54 PM
    #121
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
  2. Aug 10, 2018 at 11:38 AM
    #122
    anomalyTRD
    anomalyTRD Well-Known Member
    Oakland, CA
    2019 Ford F150
    VO Nomad
    This is a challenge on my supercharged '15 with 35s. It was not present with 255/85s. I'd love to address it between OVTune and some trans shifting.
  3. Sep 14, 2018 at 10:19 AM
    #123
    krisxone
    krisxone Active Member
    DC
    '10 TRD Sport
    @OVTune What's going on with the tuning software? You sent me an updated version, and it looks slightly different, but still cannot adjust injection scaling or afr targets. My truck has been running like crap for way too long. I sent you an email with the details on 9/12.
    -Kris
  4. Sep 14, 2018 at 10:39 AM
    #124
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I have given every possible fuel map I can't find, and fuel enrichment multipliers. I am still trying to figure out why injector scaling is not making a measurable difference.
    My software developer has left me hanging for a bit sit he's gone until after the 17th.
    I've picked through the code I cannot find any other fueling control right now.
    If you flashed the TRD map and tuned from that it should not be running really crappy
  5. Sep 14, 2018 at 11:20 AM
    #125
    krisxone
    DC
    '10 TRD Sport
    Aside from injector scaling, have you ever been able to adjust the AFR targets? Do you have special in-house software to adjust that? If you do, I'll drive the 6 hours to have you tune it. I can't get on any kind of boost because I can't adjust the AFR targets from 14.7.
  6. Sep 14, 2018 at 3:44 PM
    #126
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    So does this mean running larger 61lb injectors isn’t possible with your solution, or just “not yet”?
  7. Sep 15, 2018 at 6:49 AM
    #127
    OVTune
    OVTune
    Not yet, several updates are being worked on its just been slow since my developer hasn't returned yet.
  8. Sep 15, 2018 at 7:59 AM
    #128
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    @OVTune downloaded what I think is the correct tech stream link. It asks for dealership information for tracking. What do I do there?
    Hacktacular likes this.
  9. Sep 17, 2018 at 4:50 PM
    #129
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Email then post back. Unless you have a response already. It'll be quicker that way.
  10. Sep 17, 2018 at 4:54 PM
    #130
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I have written an email. Haven't heard back yet.
    Torspd[QUOTED] likes this.
  11. Oct 29, 2018 at 6:48 PM
    #131
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Any progress with injector scaling?
  12. Oct 29, 2018 at 8:30 PM
    #132
    ThomasMore66
    Dallas/Fort Worth & Durango
    So needy.
  13. Oct 30, 2018 at 6:10 AM
    #133
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Secondary Air System Delete capability?
    zippsub9, Watt maker and loginfailed like this.
  14. Oct 30, 2018 at 6:31 AM
    #134
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    And also catalyst monitoring delete.
    zippsub9 likes this.
  15. Oct 30, 2018 at 7:01 AM
    #135
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm almost certain I was told those are possible.
  16. Oct 30, 2018 at 7:12 AM
    #136
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I know they have done the catalyst delete for one member. He asked for it for his off road vehicle.
    Never heard solid updates for the other two.
  17. Oct 31, 2018 at 10:46 AM
    #137
    ThatguyJZ
    Jim
    TRIAD, NC
    I wonder if the system would show 'not ready' versus 'not applicable' when hooked up for inspections/OBD2. 'not ready' would fail where as
    'not applicable/available' should pass as it's saying the vehicle is un-equipped.
  18. Oct 31, 2018 at 10:48 PM
    #138
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    There are certain perameters/numbers that the test needs to meet to pass and not show a CEL. I would think that they would change these parameters/number so the sensor test always comes back good. Essentially the sensor will still be there and working but always test good and never have a CEL
    ThatguyJZ[QUOTED] likes this.
  19. Nov 1, 2018 at 8:40 AM
    #139
    OVTune
    OVTune
    it's possible in the ecu to eliminate everything where it shows "ready" as soon as the ecu gets power. But that's illegal.
    JacksonTacoma likes this.
  20. Nov 1, 2018 at 9:12 AM
    #140
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Because Race truck
