Stock Exhaust Pipe trimming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boogie3478, Nov 18, 2014.
  1. Nov 18, 2014 at 7:24 PM
    boogie3478
    boogie3478 [OP] Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Thinking about cutting off the last foot or so of my stock exhaust pipe to a few inches before the hanger. Anyone else done this for aesthetics and/or to have one less thing to bang on a rock?
  2. Nov 18, 2014 at 7:26 PM
    TopGuns
    TopGuns Well-Known Member
    Kevin
    So Cal
    08 Mid Travel
    Mid Travel, Satoshi Grill, Halo Projector Headlights, 2x 10" Kicker Comps, OEM Roof Rack,
    Yep. I cut it so it dumps right at the rear axle.
  3. Nov 18, 2014 at 7:30 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Cool. Did you DIY or take it to a shop? I'm thinking about just using my sawzall.
  4. Nov 18, 2014 at 7:31 PM
    cgchambers93
    cgchambers93 Well-Known Member
    Christopher
    Houston
    14 Tacoma SR5 4x4
    Wheels and tires, Billstein suspension
  5. Nov 18, 2014 at 7:32 PM
    TopGuns
    Kevin
    So Cal
    08 Mid Travel
    Did it myself with a a grinder with a metal cutting tip. Pretty easy. I wouldn't go to a shop and do it cause they'll charge you $$$.
  6. Nov 18, 2014 at 7:33 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I'll probably go ahead and do it this weekend.
  7. Nov 18, 2014 at 7:57 PM
    el tardo
    el tardo Well-Known Member
    worked at my friends muffler shop in HS. sawzall cuts off exhaust tubing in seconds and a very straight cut too
  8. Nov 19, 2014 at 6:27 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Cool. I figured it would with a metal-cutting blade attached. I love my sawzall!
  9. Nov 19, 2014 at 6:38 AM
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
    Did the same...wear I got a little better sound, the drone from my Flowmaster 44 disappeared, and much better clearance...GO FOR IT!
  10. Nov 19, 2014 at 7:23 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Thanks guys. I'll post before and after pics this weekend.
  11. Nov 19, 2014 at 9:08 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    My old GM s10 had a tailpipe that ended even with the side of the body and about 2" down from the bottom edge of the body. After a few years the paint above started to discolor and a few years more the paint was giving way to panel surface rust. I had to repaint it multiple times.
    My Taco tail pipe protrudes well past the body panel - or I would have added an extension tip.
    My point being, the fumes and heat from the exhaust needs to really clear any damageable painted, coated part or body paint. I'd also be sure that the composite bed does not get adversely affected as well....
