stock fender flare removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma2nd, Feb 17, 2011.
  1. Feb 17, 2011 at 6:42 PM
    Tacoma2nd
    Tacoma2nd [OP] Active Member
    06 prerunner
    2.5 inch coil spacer and rear add-a-leaf
    if 17 inch rims and 285 70 17 tires still rub my fender flares im gonna take em off. anyone on here taken there's off? how does it look? would like to see pics if you got them.
  2. Feb 17, 2011 at 7:01 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    There are a few bolts and screws holding the fender on. Look near the ends of the fender at the front and the bottom. Then there are plastic clips that hold the fender to the sheet metal. Be careful pulling on these as they will more than likely break. You will end up with a bunch of holes left where the stock flares were at.
    In this pic, no more stock flares. Just a bedliner type material over where the stock flares used to be.
  3. Feb 18, 2011 at 1:15 PM
    Tacoma2nd
    06 prerunner
    thanks man. it looks bad ass with that bedliner material. where did you get it and what did you do to put it on?
  4. Feb 18, 2011 at 3:18 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    I need to finish it off with line-x. Alot of work has gone into these fenders. Probably about 40 hours of my own time cutting/filling/sanding the fenders. Not an easy task at all.
  5. Feb 18, 2011 at 6:22 PM
    Tacoma2nd
    06 prerunner
    yeah i bet. its worth it though cus it looks really good.
