stock fit 33s
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoTuesdayyy, Aug 27, 2014.
  1. Aug 27, 2014 at 6:45 PM
    TacoTuesdayyy
    TacoTuesdayyy [OP] Active Member
    Ben
    Albuquerque New Mexico
    04 TacomaV6 TRD sr5 Xtracab 4x4
    2.5 inch Leveling kit in front, 4x4 foot Smittybilt Defender roof rack sitting on custom built bed rack, Trail Gear Stinger bumper for first gen 4runner with adapter bracket, 2 inch shackle kit on rear leafs, Smittybilt 10,000 pound winch, Two 7" HID spots mounted on custom light brackets under stinger, Train Horn, 35x12.5x15 Cooper MTPs , Various LED Pods and 42 inch light bar.
    can the stock suspension on my 04 fit 33s? even if its a little tight?
  2. Aug 27, 2014 at 9:10 PM
    mtbskilz
    mtbskilz Member
    Denver Co.
    2004 sr5 3" lift black
    3" lift, pro-comp alloy rims black, shrockworks front bumper, piaa driving lights, piaa fog lights, warn m8000, AEM intake, optima yellow top battery, custom cat back with glass pack, viair hd on bored air system, kolbolt tool box. soon to be SASed
    If it was posable I think more people would be doing it. In most cases though you will need about a 3" lift and wheels with less backspacing and or wheel spacers so you can clear the upper control arm or some major cutting to the body which i don't think you want todo judging from your question. personally I would save some money and buy a good 3" lift, wheels, and diff drop (if 4x4) and do it right the first time as having to redo work just sucks and is more expensive in the long run. that is my take at least.
  3. Aug 28, 2014 at 2:28 PM
    Devious81
    Devious81 Toyota Tech
    Omaha, NE
    '16 White TRD Offroad DCSB
    Slight lift, 285/70r17 Goodyear Duratracs.
    ^^^^^^^^Exactly what he said. 32ish inch will fit without rubbing with 5100's on the front set to the middle setting, currently what I have at the moment.
  4. Aug 29, 2014 at 7:27 AM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    They will fit just fine... Just don't turn or go over bumps!
  5. Aug 29, 2014 at 12:04 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    you're not serious right?
    read through the Wheels n Tires section.
    use the search tool.
    short answer; not without tubbing the hell out of your wheel wells.
  6. Aug 29, 2014 at 12:06 PM
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
  7. Aug 29, 2014 at 2:29 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    See above
  8. Aug 29, 2014 at 2:38 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Negative. No need to tub for 33s.just rip out the plastic wheel trim, then beat the fuck out of the pinch weld area.
    If you run 10.5" wheels you can get away with factory wheel spacing. 12.5s will need about 3.5" of bs
  9. Aug 29, 2014 at 2:41 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    no need to insult me. a simple rebuttal answer would have sufficed.
  10. Aug 29, 2014 at 2:42 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Still willing to bet that tire will eat the inner wells if offroading & in a corner tho'..
    I hate back spacing, FWIW I never heard of BS & all its references until I got here...
  11. Aug 30, 2014 at 3:16 PM
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    I didn't find his reply any more insulting then your , "Your not serious right?" :confused:
  12. Aug 30, 2014 at 8:54 PM
    04rktaco
    04rktaco Well-Known Member
    Lee
    California City, Ca.
    '04 4x4 xtra cab 4x4 TRD. 2014 Tundra crewmax TRD 4x4
    All Pro UCAs King coil-overs All Pro rear springs Modified All Pro Bumpers. Home made skids and sliders. Lefty 4.7 transfer case. Stock e locker rear stock 4:10's Tundra Brakes 285/75/16 Falcon Wildpeak AT3W stock wheels with 1.25 spacers BAMF lca skids. 2014 Tundra crewmax TRD 4x4 5.7 v-8 with leather interior. RCI Metalworks full set aluminum skidplates All Pro rock sliders
    Unless a lift limits up travel 33's won't fit any better than they would without a lift. I'm running about 2 1/2" of lift up front 3" in back and some sledge hammer work in front and minor cutting front and rear with 285/75/16 Goodyear MT/R's on stock TRD wheels with 1 1/4 wheel spacers and they still rub a little in front but not enough to bother me. Would have to tub or maybe install 1" body lift to get no rubbing at all.
  13. Aug 31, 2014 at 5:50 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    A lot depends on your driving style, the big thing about 33's on a Tacoma is not the lift but the size of the wheelwell which is pretty small so if you drive hard and bury your tires in the wheelwells then you need a proper lift. As for rubbing on the UCA's that is more a product of backspacing and the width of the wheel, not enough width gives a bulge in the sidewall that will rub. Standard backspacing is 4.5 inches so if your wheel and tire setup keeps the distances the same as stock the UCA shouldn't be a problem but it all comes down to the size of the wheelwell. I would suggest that you find someone with a set of 33's you can put on to size the situation up then you will see what everyone is talking about.
  14. Aug 31, 2014 at 10:10 AM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    that was a simple question about the validity of his question. you see without tone, you added your own assumed tone to my question, in turn changing it's neutrality into negative commentary :D
    in added response to this thread, I doubt the plastic is the only thing 33's will hit when at full flex and full lock turn. I understand that removing all of the plastic and altering the pinch weld will allow for wheel travel in MOST situations on the road, however, once off road and on a surface where no two tires share common ground it would become readily apparent that more trimming and even some cutting and rewelding would be necessary to gain FULL wheel travel in all directions, at all positions.
    but of course, everyone is fixated on starting a pissing contest rather than answering the original question.
    OP, if you do not off road and are content with rubbing on occasion then you can run 33's and cut or trim your wheel wells accordingly.
  15. Aug 31, 2014 at 11:22 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Not bad, hit all the Key points, especially the 33" reference, I've never seen so many different sized 33"'s (or claims of) One manufacturers "33" will be noticeably larger or smaller than another, yet ALL will claim theirs is a 33".... Can't win, I blame it on the metric system...;)
  16. Aug 31, 2014 at 4:59 PM
    Devout
    Seattle
    03 TRD 4X4
    None yet
    IIRC, Interco, Dick Cepek, and a handful of the 'boutique brands' run true to size. All others tend to fudge a half to three-quarters. Guess marketing tires is like marketing condoms. Heck, rubber is rubber, no? :eek:
  17. Aug 31, 2014 at 5:10 PM
    Devout
    Seattle
    03 TRD 4X4
    None yet
    1) Ahhh, so before you answered, you were asking him if he was a troll? Or were trying to stultify him? Either way, not called for in polite conversation.
    2) I try not to pretend to know what others may feel or think, so I only answer from my point of view. Helps to avoid misunderstandings. So yes, that was how I saw it.
    3) Once again, we can only see from our point of view, so read what you posted in three.
    Again, if you feel people are not being duly polite when they respond to you, perhaps they viewed your response as impolite. So, in conclusion, if everyone goes above and beyond to be polite, your assumption in number three will never become an issue, will it? ;)
  18. Aug 31, 2014 at 9:50 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I agree. I went back and changed part of it when I realized it was too harsh.
    like you and others said. depends on size and BS which you loathe :p
  19. Aug 31, 2014 at 9:59 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    33 1250s with 3.31 BS, pinch weld, and a hair over 3" No rub, except on full stuff and turned all the way to the right.
  20. Aug 31, 2014 at 10:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Haha , yeah thats what I always thought as well, but you're right about "true to size" companies, My Cepeks were 36.5" x 14.50" x 15" & 38.5" x 14.50" x 16.5" you could throw a tape on it & the numbers jived
    You KNOW I fucking hate it !! We didn't have those kinds of issues, if your truck was high enough (was never a problem my Dodge was 7" over stock) & they fit reasonably in the wells, you ran them, usually with no issues
    It's like squeezing that last inch out of an IFS, it can be done but its going to cost you $$$ & worse all the labor hours to get it, you just dont care anymore , not worth the cost or hassle....:p
