Stock Fog HID Conversion ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stanley, Mar 22, 2011.
  1. Mar 22, 2011 at 5:30 PM
    Stanley
    Stanley [OP] Well-Known Member
    Breckenridge, CO
    06 SR5 Silver
    Debadge, 5% Tint, Kolbalt Low Pro Tool Box, Satoshi, Ebay Black Headlights, 3000k Fogs With Yellow Stain glass Paint, Fog Anytime, Mag Light Mount, Husky Floor Liners, OME 3inch With 885's, Add Leaf, 16inch Steelies, 305/70/16 Dick Cepek Mud Countries, Tiregate Bed Mount, Sock Monkey Badges
    i know there are write ups on this but no1 is responding and im trying to order from ddm right now. i did the headlight swap the other day. took me 20 min. have a question about the fog lights. so you go from factory connector of the fog light to the ballast to the bulb. no ground or power source from battery? im assuming this process is just for the controller (high/low bulb) on the headlights? im trying to get the slim kit from DDM. what bulb type H10? if anyone wants to just tell exactly i need it would be much appreciated.
  2. Mar 22, 2011 at 5:43 PM
    BlueSteel
    BlueSteel Well-Known Member
    James
    The Woodlands, TX
    09 Magnetic Grey Doublecab TRD Sport Debadged
    Camburg 4" Spindles, Icon CB 2.5 adjustables front and rear, Total Chaos Upper/Lower CAs, Alcan 5" Rear Leafs, Timbren Bumpstops, 5" SS Brakelines, 295/70/18 Nitto Trail Grapplers on 18" KMC Monsters, Grill Craft Black Mesh Upper, Predator Running Boards, All Pro Rear Bumper and Hitch, Wet Okole Covers, Toyota Roof Rack, Limo Tint, TRD CAI, TRD Exhaust, Weathertech Mats, Redline Hood Struts, Red Top Odyssey battery, BDF Light Bar, Foglight anytime Mod, Lo Pro QT Truxedo Tonneau cover, Rocky Mount Bike Pegs.
    H10. If you did some trimming on the inner fender plastic, it will make it so much easier in the future to change out bulbs or adjust the fogs. If you take off the front grill, you can mount all the balasts and run the wiring pretty easily.
  3. Mar 22, 2011 at 5:44 PM
    smurf taco
    smurf taco Well-Known Member
    Brian
    Hobe Sound, Fl
    speedway blue 09 prerunner sport 2wd
    brite ass led headlights and fogs, fuel hostage wheels, mellow tone dual exhaust, black westin bull bar, go rhino nerf bars, toyota neoprene black and blue seat covers, image dynamics door speakers all around, Bilsteins 5100s all around set at 0 with maxtrac spindles and eibach coils and total chaos UCAs with OCtaco brakelines all around and all pro expo leafs in the rear running 295/70/17 cooper ST Maxx, cobra cb radio w/ 3ft fire stik, bed lights, jvc double din head unit, AC in cab mod, AFE CAI...more mods to come
    yea its just a ballast and 2 wires that plug into to your factory harness....nothing goes to the battery just 2 wires from the ballast and 2 wires from the bulb and the fog light bulb number is 9145 and the headlight is hb2
  4. Mar 22, 2011 at 5:45 PM
    mixplatexr
    mixplatexr NGDEUCE
    Palani
    Wahiawa, HI
    2007, SWB X-Runner
    RGM, FLM, Morimoto Mini D2S Retros, BSP/SMOKE Tinted Taillights/3RD Brake Light, SS W/3INCH REAR, QA1s, WeatherTech Vent Visors, WeatherTech Digifit Floormats, Kenwood DDX719, 2 RF HE Punch 12s, aFe Stage 2 SI, NST Crank Pulley, DTLT Headers, SpinTech Super Pro Street, URD SS W/Coupe Arm, 18x9.5 White XXR 522, Viper 5901
    As everyone else has stated, just get the H10 Kit. The wire is usually long enough to have your ballast up around by your headlights/grill
  5. Mar 22, 2011 at 5:50 PM
    Stanley
    Breckenridge, CO
    06 SR5 Silver
    so no harness needed just the base kit?
  6. Mar 22, 2011 at 5:58 PM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    i still say its safer to do the relay and stuff. dont wanna blow fuses or burn up your wiring/truck. dont kick yourself in the ass later. get the wiring harness. Just some advice.
  7. Mar 22, 2011 at 6:00 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    also IIRC, reading somewhere here.. .55w will do dmg to the fog light housing? or some sort of discolor?
  8. Mar 22, 2011 at 6:02 PM
    AsianAnts
    AnT
    D: regardless if its retrofitted?
  9. Mar 22, 2011 at 6:05 PM
    BlueSteel
    James
    The Woodlands, TX
    Yep, don't bother with the 55W or this will happen to you. I have also seen it on a handful of other vehicles also. The headlights were 55W 6000K HID's and the hue changed from a slight blue to pink. :eek:
  10. Mar 22, 2011 at 6:12 PM
    AsianAnts
    AnT
    aww shiet?? kuz im getting a retrofit service done and requested for 50w....... lol
  11. Mar 22, 2011 at 6:12 PM
    Mtnbker343
    Mtnbker343 Well-Known Member
    Binghamton, NY
    2016 TRD Sport
    18" XD Monster wheels with a 4.5" backspace and a set of P285/60/18 Nitto Terra Grappler tires....Toyteclifts 3in coil and add a leaf. Window tint. tonneau cover.... more to come!!!!!
    Just a heads up on DDM there are so back ordered on everything they sell right now....... i ordered HID kits for my headlight and fogs 3 weeks ago and just got a e-mail after i sent many asking where my lights were they don't even excpet to get more in for another 4 weeks..... i ordered 3 weeks ago and its might be over aother month before i see them.... i'll keep you posted
  12. Mar 22, 2011 at 6:16 PM
    AsianAnts
    AnT
    nuu, remember i was gonna go visit you and shine it? LOL...
  13. Mar 22, 2011 at 6:16 PM
    BlueSteel
    James
    The Woodlands, TX
    This was Slim's kit from the Group Buy...lol Slim's customer service has been great though. I actually bought 3 kits from him.
  14. Mar 22, 2011 at 6:22 PM
    AsianAnts
    AnT
    :)... i fling poo... cow poo.... man oh man does chino smell sometimes... anywho, should i modify my order for a 35w? unlike the picture, the bulb is in the projector... and not in the housing directly..
  15. Mar 22, 2011 at 6:25 PM
    BlueSteel
    James
    The Woodlands, TX
    I would because the 35W Is plenty bright and I have not seen any type of hue change. To be honest, the 55W wasn't as bright as I thought it would be. I also like the 35W slim ballasts more than the 55W ballasts.
  16. Mar 22, 2011 at 6:29 PM
    AsianAnts
    AnT
    well then....ill keep my headlights 35w, my fog lights 35... then my hellas 55!!!!!
    just like the OP, imma run HID for my stock fog soon
  17. Mar 22, 2011 at 6:46 PM
    BlueSteel
    James
    The Woodlands, TX
    All 35W 6000K slim ballast kits. The grill has Hella 700's converted.
  18. Mar 22, 2011 at 6:50 PM
    BlueSteel
    James
    The Woodlands, TX
    Thanks!
