Stock Fog Light Wiring
Discussion in 'Lighting' started by IndianTaco, Sep 16, 2012.
  1. Sep 16, 2012 at 5:53 PM
    IndianTaco
    IndianTaco [OP] Well-Known Member
    I installed an aftermarket bumper and was wondering if i can hookup aftermarket driving lights the stock fog light wiring harness?
  2. Sep 16, 2012 at 7:02 PM
    09DBLCAB09
    09DBLCAB09 Well-Known Member
    Yes. Depending on the details of the lights
    How many watts?
  3. Sep 16, 2012 at 7:13 PM
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    Holy shit balls I have the same question.
    I am installing RI Duallys. Watts 15, Amp Draw 1.
    I tried jerry rigging the RI connector to the stock one just to see if it would work, but no dice. If it matters, I was doing this when I was doing BHLM and had all lights disconnected from harnesses. Maybe it didn't turn on cause the other lights were disconnected? Comparison, a light on a christmas tree?
    Anyways, can I wire these directly to the existing OE harness and be G2G?
  4. Sep 16, 2012 at 7:15 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Factory bumper mounted fogs only come on with the low beams unless you've done one of the several "any time" mods (which may get you into trouble at inspection).
  5. Sep 16, 2012 at 7:19 PM
    TeamLombardo
    Tony
    El Paso
    i do have the mod
  6. Sep 16, 2012 at 8:54 PM
    IndianTaco
  7. Sep 17, 2012 at 10:53 AM
    IndianTaco
  8. Sep 17, 2012 at 10:58 AM
    98tacoma27
    Ben
    Not Beech Creek
    What's the wattage of the lights you wish to install?
  9. Sep 17, 2012 at 11:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The Duallys will be fine running on the stock wiring. The PIAA's might be pushing it. I think the lower wattage PIAA's are 55 watts which would probably be as high as I would ever want to go off the stock harness/wiring. Anything higher than that and you should think about re-wiring.
