Stock Foglights Fitted In Relentless Plate Bumper
Discussion in 'Relentless Fabrication' started by IluvTEA, Mar 13, 2011.
  1. Mar 13, 2011 at 8:47 PM
    IluvTEA
    IluvTEA [OP] Well-Known Member
    South Dakota
    '10 DC LB 4x4 SR5 Super White
    Cooper ST 265/75/16 on Flat Black TRD OR wheels, window tint, blacked-out badges, front mudflap trim, BHLM, Base Black Rear Bumper Swap, Color-matched grille, Custom Relentless Fab plate bumper powdercoated flat wrinkle black and "TACOMA" backlit with Drunknsloth LEDs, Camburg 2.5" coilovers, LR UCAs, Power sliding rear window, Back-up camera anytime, FX-R projectors/Morimoto 3Five Ballasts/D2S bulbs 5000K, Black WeatherTechs, heated TRD seats with Roadwire Graphite Leather, OEM Roof Rack, front mud flap delete, Black Level 8 Guardians, TreadWright 285/75/16 with KG ...
    Hey there TW!
    As you know I got my Relentless Fabrication front bumper put on a couple weeks ago and I finally got time to try and rig up a way to put the stock foglights into the foglight housing. Now, I know that I probably could have sold the stockers on here then picked up some cheap foglights from Wal-mart and came out ahead. But since wiring isn't my strong suit, I decided that I wanted something plug-and-play using the stock ones.
    Here is what my wife and I came up with. Since the back of the foglight is plastic, I didn't want to drill into it and connect it to the metal L-bracket on the back of the bumper.
    Here is what we bought from the local hardware store:
    (2) 4" to 3" Rubber Coupler (4" hose clamp was attached)
    (1) package 11" zip ties (you need about 8, but its good to have a couple extra)
    (2) 3" hose clamp (not needed, so don't buy it) :eek:
    (1) foam pipe insulator (not needed, so don't buy it) :eek:
    Alright, first step is to squeeze the foglight into the 4" side of the coupler. Slide it in deep enough so its about a 1/2" from the front of the coupler.
    Next, slide the zip ties in between the foglight and the coupler. (Here you can see I cut the foam pipe insulator to act as a barrier between the metal bumper housing and the lens of the foglight, but I decided it wasn't necessary.)
    Here's a pic of it without the foam piece (again, I didn't use the foam piece because the foglight was so tight against the bumper there is literally no movement).
    Then I trimmed out a slot for the L-bracket that is welded on the back of the bumper to hold your aftermarket foglight. (you could also notch it out all the way, but having the slot helped to hold it in place while I tightened the zipties and will help secure it better in the long run.) The alignment screw on the back of the foglight is the bottom, make sure you cut the slot on this side so the foglight is straight. (I used the extra L-bracket that Eric sent line up where the slot should go and to test out the size of it.)
    Next, sqeeze the foglight behind the bumper. (this would be a little easier if you did this before the bumper is installed)
    Slide the L-bracket into the slot you cut and pull the rubber coupler around the metal housing on the bumper.
    Take the 4" metal hose clamp and put it around the zipties and tighten it around the metal housing. (make sure the rubber isn't under the clamp)
    Tighten the zip ties.
    Plug in the foglight.
    Here is a pic from the bottom showing the L-bracket coming through the slot in the coupler.
    Another mod done!!
    Hope this helps some of you out. Let me know if you have any questions or need more pics.
  2. Mar 13, 2011 at 9:10 PM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Sweet! Great mod, I'm gonna try it in a couple months when we get the bumper!
  3. Mar 13, 2011 at 9:14 PM
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Awesome job! I will be checking this again once I get my bumper, I really wanna keep my stock fogs for the hid aspect.
    +rep sent :thumbsup:
  4. Mar 13, 2011 at 9:16 PM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    Nice! I used only the clamps and clamped the fog light to the L bracket and then the L bracket screwed on to the fog light adjustment bracket. $5 mod and holds on great!
  5. Mar 14, 2011 at 1:11 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Badass! Thanks for posting this. Many will find it useful, and you made it easy for me since I can just tell people who ask to check out this thread! :)
    +rep to ya man!
  6. Mar 14, 2011 at 1:14 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Gonna have to try this on mine. When the time comes it will be an easy swap to the relentless :D.
  7. Mar 14, 2011 at 1:17 PM
    RelentlessFab
    Eric
    Sparks, NV
    This method probably wont work on the AP if thats what you're going to try and do this mod on. The AP uses some cutout plate steel with a few bends to fill around the fog lights (I believe its a hex shape) rather than the round tube that I use so the round coupler probably wont fit the AP's recesses.
  8. Mar 14, 2011 at 1:24 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Ya thats what I'm talking about. It is a hex shape, but the rubber should have enough are to grip. Its worth a try though, those piaas are way too expensive for me.:D
  9. Mar 14, 2011 at 1:26 PM
    RelentlessFab
    Eric
    Sparks, NV
    I'd measure how large the shroud is across before buying any parts. I think the shrouds are a bit bigger on theirs too, possibly in the 5- 5.5" neighborhood behind the 4" hole in the bumper.
  10. Mar 14, 2011 at 1:29 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Ya I would be measuring first. But it will be summer (2 months away for me) before I do this. So I have lots of time to think about it.
  11. Mar 14, 2011 at 9:42 PM
    IluvTEA
    South Dakota
    I forgot to post prices...
    the couplers were about $7 each and the zipties were a couple of bucks...
    Thanks for the reps, glad I could help!
  12. Apr 16, 2011 at 11:41 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The fogs don't melt the rubber of the Fernco fitting ?
  13. Apr 16, 2011 at 11:50 PM
    RelentlessFab
    Eric
    Sparks, NV
    You think it would get that hot? Thinking about it... isnt the whole plate bumper essentially a heat sink when the lights are mounted that way? Plus theres the wind of driving cooling everything too....
  14. Apr 16, 2011 at 11:54 PM
    OZ-T
    Peter North
    British Columbia
    The bulb is in direct contact with the coupling which is why I asked , seems like a good way to mount them up , I wonder if I'll be able to stretch a 4" fitting over the slightly bigger tube on the aluminum bumper .
  15. Apr 17, 2011 at 12:20 AM
    RelentlessFab
    Eric
    Sparks, NV
    true. Im not sure if you will... I think that tube is like 5" OD on the aluminum bumper
  16. Apr 17, 2011 at 12:25 AM
    OZ-T
    Peter North
    British Columbia
    I wonder if I can get a 5" to 3" Fernco , looks like a call to my plumber is in order . :)
  17. Apr 17, 2011 at 9:29 PM
    IluvTEA
    South Dakota
    OZ-T,
    I was driving around for a few hours and had the foglights on for a solid 2.5 hours. Right afterwards I checked if the fitting and it wasn't even warm. I felt the lens and it was slightly warm. I also stuck my finger on the back of the foglight housing it wasn't warm at all. I don't think the heat will be a problem. Perhaps if you have HIDs, do they get hotter because they are so much brighter?
    Hope this helps.
  18. Dec 21, 2011 at 5:22 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    doing this today.:cool:
    anyone want PIAA 510 xtreme white's:D
    never used but the decal that comes in the box is missing:)
  19. Dec 21, 2011 at 2:12 PM
    crf69
    Ohio
    ummm yeah
    works great thanks
  20. Dec 21, 2011 at 2:45 PM
    IluvTEA
    South Dakota
    Glad it worked out for you! I haven't had any problems and they've been on for over 9 months!
